Dyno Result It, What Do U Think?
kay33
 Share
hey guys, i have a 94 skyline r33 gtst-auto. my mods are xforce turboback exhaust, blitz lm podfilter, greddy fmic, turbosmart dual stage boost controller, and greddy e-manage. the car was boosted to 14psi, and made 209.5kw at da rears. What do u think? and is 14psi 2 high?, i dnt noramlly hit 14psi unless im dragging some1 which is rare. cars normally crusing at round 9psi.
id say put the boost down before you shit your turbo. Id also say your kilowatt reading is on par for your mods
:D
happy dyno :D
bit like the dyno you use is it Mafia?
why make stupid remarks? the power seems ok seeing as its running aftermarket ecu (sort of)
and the stock converters and trans dont rob that much power.
if he had a high stall i would call BS but otherwise i say well done.
Dyno I use is unhappy. Cars coming off this Mainline and going onto Dyno dynamics are running 20rwkw more.
So no, its not a stupid remark. But then again, he is running 14psi (which will make his turbo take a dump)
9rwkw is a fair bit of power for the auto to take, so a manual on his engine would make 223rwkw with the stock turbo? I don't think so.
A lot of tuners like to make high false readings so that young fellas get their wallets out faster. Seen it a million times.
:P
I'm planning on adding an SAFCII to my R33 and pumping the stock turbo to 14psi.
U saying i need a new turbo then? :unsure:
 Share
    • I did manage to do this without removing the engine or front cross member, but I had the advantage that the exhaust manifold was removed. I am not setup to support the engine from the top or remove it. 1. Loosen the engine mount nuts so they only have a nut of thread. If it is a manual, I think you have to remove the gearbox to engine support brackets. 2. Jack up the engine off the bottom idler mount. Jack it up till the end of the slot and nut on the mount. You need this clearance to get the pan out at the rear of the engine. 3.Break the sealant seal to sump. I found a oil pan separator tool helpful to get it started. 4. The oil pick up can be removed with the gap available.  5. The oil pan can be removed now. 6. Before assembling, do not apply sealant to the oil pick up area as your hand will rub it all off but apply to the other three and a bit sides. 7. It is a two man job to put the oil pan back, with the sealant, as you do not want it to touch anything and rub off. 8. With one person supporting the oil pan the other can fit the oil pickup 9. Apply the remaining sealant. This would be more difficult with the manifold or turbo in place, but I think it could be done. As you can see my sealant is a bit ugly, but good enough to seal. 10. Lift the sump up to the engine and bolt it on. We found it was easier to use two long guide bolts at each end to get it nice and aligned without touching.
    • I find building an exhaust a really satisfying job! Looks nice!   Did you consider using an oval pipe to get the same cross sectional area but keep it above the chassis rail?
    • @Dose Pipe Sutututu Sounds good.  Just double checking with the pull up resistor indicated in haltech's info sheet for their SSR - https://www.haltech.com/product/ht-030202-solid-state-relay-100-amp/  I'm guessing that would only be if the ECU did not have an internal pull up resistor? Their instructions are pretty strongly worded lol "1K pull-up resistor MUST be fitted."
    • I wouldn't think you would need a flyback diode, as it's an OEM replacement parts for a fan controller/relay on a Dodge. Another tried and tested option are the Volvo XC90 (or similar) fan controllers.
    • Just checking, with this would you need anything else to get yourself up and running? Do I need a flyback diode, pull up resistors or anything else?
