Hi guys,
Im currently upgrading my gtt to make 250 odd rwkw safly. now here is my current list of mods,
Turbo back 3inch
HKS fmic
Splitfires
nismo panel air filter
ebc (profec b) set to 10psi
to achieve my goal (250rwkw) i have purchased the following (yet to install)
Emanage Ultimate
HKS Gtrs kit
Nismo 480cc injectors
Tomei gtt fuel pump
Z32 air flow meter
Now my questions are
A. 250 rwkw reliably? any suggestions?
B. is a FPR neccisary on my setup?
Thanks Guys :D
Edited by silverr34gtt
https://www.sau.com.au/forums/topic/184402-injectors-and-fpr/
all the mods that you need for your power goal are all there. Id say 480cc injectors should be ok without a FPR but if you want one i dont see how it wont be beneficial if you need to increase the fuel pressure. Other than that i hope youve upgraded your clutch and got good tryes to get that power down. good luck
throw the FPR in the bin, and get a set of Nismo 555cc injectors. They'll be the same price as most Nismo injectors.
That will make 250rwkw reliably.
errr you still need a reg, you can't just get rid of it completley......
Id get a reg as well, if nothing else just for piece of mind so you know you've got good fuel pressure. One of the nismo ones are fine and fairly cheap as well.
he dusnt NEED one..but yeh as mafia said, with 550cc injectors u wouldnt need one, but if youve spent money on the 480's already then just get a reg so that its there if fuel pressure is needed
ok so 480's plus a reg will be ok. Yes ill need a clutch before i finish these upgrades
as for tyres i have a set of bridgestone re001 adrenilin's so that wont be an issue (awesome tyres).
Thanks for the input.
perhaps were are talking about weather or not he needs an adjustable one. I didn't think you could just take the reg out of the system altogether and not have one. Whats going to govern fuel pressure if there is no reg in the system?
fpr's are also great if you buy injectors that are too big they can help down tune them so you dont over fuel the car, wont people dont look at it that way but they can help out there, hope that helps
ok maybe i wasnt clear enough,
im not saying get rid of the regulator all together. im saying is it necisary to buy an adjustable one. or would the stock one be ok with the increase in flow from the tomei fuel pump. the difference is quite big, standard fuel pump 130 l/min tomei 258 l/min.
would this increase require the after market regultor or will the stock one bypass the exess flow?
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
