Hi guys just recently installed the iebc from jaycar in my r33, after installing the unit and hand controller they seem to be working but I am having problems with the tuning and was wondering if anyone could help or might know the problem. Im having difficulties with the H/C, its not saving the output or inputs when I get to the boost level that I want. Also the solenoid is working but it comes in hard at 10-80% and 0% solenoid is closed as well as 100% (not chattering away). Just wondering if anyone can tell me how the tuning side of things is supposed to work, as I cant setup a cycle . When testing the solenoid it runs in view and run mode? Is that supposed to happen? Any help would be massively appreciated as it is becoming really frustrating……
https://www.sau.com.au/forums/topic/184407-jaycar-electronic-boost-controller/
Are you getting any input? ie from the injector?? Should be running from 1-64 points.
Run mode is live mode, select this mode when you start your engine and should read -1-2-3 or something and then as revs rise this rises as well.
View mode is where you change your solenoid settings (outpt %) accordingly to your input settings.
To set it up, you really need someone watching the H/C as you hit your desired boost settings. If its at load 30, you may want to start opening your solenoid.
