77 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 42
lol @ ^
lets face it, the broad answer to this broad question is - wider is better.
your getting too technical.
think of it this way. these two guys had a few beers, watching ralph tv, maybe some cones, and then 1 says skinny tires are better than wide.
what do you do?
*SLAP* i'm rick james bitch
LMAO
in the dry wider tyres will grip better. in the wet if they are too wide they are more likely to aquaplane as they have to pump out more water.
more grip isn't always a good thing though. the trade off with grip is resistance. a wider tyre has more resistance, so at higher speed wider tyres can reduce acceleration and top speed.
for the drags you want as grippy (not necessarilly the widest) tyre you can get as the launch is all about grip. a supper tacky 225 will grip better than a rock hard 305. but then once you are up and going and have no problems with wheelspin you want a skinny tyre again to reduce resistance. and on the front you would want as skinny as possible to reduce rolling resistance.
for track work you want grip all round so you even up the tyre sizes since the front needs grip to stop the brakes locking (a gbetter tyre will let you brake latter than bigger breaks (unless you are unable to lock a wheel with your current brakes), as bigger brakes will make it easier to lock a brake, but better grip means the road will keep forcing the tyre to keep rotating under a higher breaking force) and give you turn in without understeer.
if you got 2 tyres of the same compound, 1 a 225 and the other a 245 then the 245 would have more grip as they are the same compound, but if you get a 235 semi slick and a 265 cheap chinese tyre the semi slick will be much better.
    • Ah yes, fair enough! I was purely thinking about cleaning the spokes and front of the wheel with the mitt. For the barrel the rag on a stick makes more sense. I've tried cleaning the barrels on mine and gave up in frustration. Between brakes being in the way or spokes being in the way and limited space to constantly move the car front and back it was just too annoying. The barrel being as shiny as the rest of the wheel sounds amazing though. At this point I'm not even sure if they have the same surface finish on mine. But I feel inspired now to find out.
    • I have a wheel cleaner pokie thing which is a glorified microfibre rag on a stick, and there is not sufficient clearance between the caliper and the barrel to clean that section. I just roll the car forward 500mm and have another shot at each wheel.
    • The "rag on a stick" is a easy way to fit in between the wheel spokes into all of the barrel Albeit I do have 10 spokes on the MX5 which limits the access to actually jam my hand in to clean the barrel, but it was also makes much easier to clean the 5 spokes on the Dunnydoore with it as well, as you don't have to worry theΒ  caliper getting in the way if you have at least about 15mm space between the caliper and barrel This of course depends if you actually have the clearance between the barrel and caliper, and the amount of OCD you have to get the barrels as clean and shiny as the face of the wheel The thing is bendy as well so you can actually shape it to conform to the inner lip of the barrel Β
    • FWIW, as well as a basic immobiliser/remote unlock (all basic units give you those 2 things), I would also install a 4g tracker in any car I cared about. Just hide it anywhere that won't be found in a rushed look and preferably get something with a built in battery backup so it stays online for a while when the battery is removed or flat While its not a car, when our car trailer was stolen in that den of crime Sydney about a decade ago, the cops were watching from the bloke's neighbour's lawn within about 2 hours until he started swapping the plates and putting up the gumtree ad.Β Β  Obviously it is still not undefeatable (eg parking it up for a few days somewhere without sky sight) but it greatly improves your chances of getting it back quickly and with less damage
    • Instead of magic keyphrases I wonder if something can be done with auto complete. Similar to how user names are handled already. When you type '@' and follow with letters, it'll search across all usernames. It might work to have the same for forum topics. Some key to trigger it and then text search across all thread names and it'll insert the name and URL when pressing enter.
Γ—
Γ—
