hey guys,
Using the basic TIEN (height only adjustable) coilovers with pillow ball tops in them, Its been brought to my attention by a few people lately that they are noisy as hell. Everytime i go over a bump they make noisy clunking noises. It seems to be getting louder and louder...They are still very stiff, they aren't showing much sign of wear except for this...or is this normal for pillow ball tops?
thanks guys
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/
Ive got TEIN Coilovers and they are silent, but mine are the ones that are re-designed by Fulcrum to better suit Aus roads.
Are yours imported?
If they are they're probably not very well suited to Australian roads and they will be extremely stiff, a friend of mine put Jap spec TEIN's in his R33 and it was so stiff that you needed a kidney belt to ride in it and they were also very clunky, it sounded as if they were loose but we checked every bolt and they were all fine, I think it has something to do with the internals of the shock- when they get older they start to get very noisey, so he took them out.
However Ive had mine for about 12 months now and they are as quiet as they were when they were new.
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3341041
I got Teins Super Streets and mine only make a clunk noise if i hit a bump which i would expect lol - But my rear left hand side one does squeek but haven't had time to remove back seat to check it isn't anything in there but apart from that silent.
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3341785
I've got tein ha coilovers (Jap spec) at the moment and the rear ones clunk, especially at low speeds. They still work fine, but am sure somethings loose inside or worn out.
I like the way they ride, so going to Aus spec one's will be softer and I'll need to get some whiteline swaybars to reduce the bodyroll I'm gonna get!
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3341820
Unfortunately, that's just the way Tein HR's (HR's are high springrate coilovers just like HA's, but without all the adjustability) end up after a while. Most are fairly old now and just about every car I've been in that's had them rattled like crazy. I say time for an upgrade! :)
Edited by AZN25T
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3345191
yea its kinda rattley... i just had a look and it says HR on them.....what sort are these...everything is tight...didnt check the top of the strut towers tho....they didn't move at all with a bit of persuasion
hr's are as stiff as sh*t and ha's i have a half set of each sitting in the shed for that reason,go and grab some of the aus spec ones handles and rides like a completely different car.also when i pulled my hr coilovers out and pulled them apart they had next to no oil left in them!
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3345785
My experience with Tein suspension has been a nightmare. :kiss:. They are the stiff-est i've came across. Have since changed them to HKS suspension.
Those with jap spec teins might want to send them to Fulcrum to get them reconditioned when they start to make noises. Fulcrum will probably rebuild them to be more suitable for australian roads.
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3345882
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
