hey guys,
Using the basic TIEN (height only adjustable) coilovers with pillow ball tops in them, Its been brought to my attention by a few people lately that they are noisy as hell. Everytime i go over a bump they make noisy clunking noises. It seems to be getting louder and louder...They are still very stiff, they aren't showing much sign of wear except for this...or is this normal for pillow ball tops?
thanks guys
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/
Ive got TEIN Coilovers and they are silent, but mine are the ones that are re-designed by Fulcrum to better suit Aus roads.
Are yours imported?
If they are they're probably not very well suited to Australian roads and they will be extremely stiff, a friend of mine put Jap spec TEIN's in his R33 and it was so stiff that you needed a kidney belt to ride in it and they were also very clunky, it sounded as if they were loose but we checked every bolt and they were all fine, I think it has something to do with the internals of the shock- when they get older they start to get very noisey, so he took them out.
However Ive had mine for about 12 months now and they are as quiet as they were when they were new.
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3341041
I got Teins Super Streets and mine only make a clunk noise if i hit a bump which i would expect lol - But my rear left hand side one does squeek but haven't had time to remove back seat to check it isn't anything in there but apart from that silent.
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3341785
I've got tein ha coilovers (Jap spec) at the moment and the rear ones clunk, especially at low speeds. They still work fine, but am sure somethings loose inside or worn out.
I like the way they ride, so going to Aus spec one's will be softer and I'll need to get some whiteline swaybars to reduce the bodyroll I'm gonna get!
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3341820
Unfortunately, that's just the way Tein HR's (HR's are high springrate coilovers just like HA's, but without all the adjustability) end up after a while. Most are fairly old now and just about every car I've been in that's had them rattled like crazy. I say time for an upgrade! :)
Edited by AZN25T
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3345191
yea its kinda rattley... i just had a look and it says HR on them.....what sort are these...everything is tight...didnt check the top of the strut towers tho....they didn't move at all with a bit of persuasion
hr's are as stiff as sh*t and ha's i have a half set of each sitting in the shed for that reason,go and grab some of the aus spec ones handles and rides like a completely different car.also when i pulled my hr coilovers out and pulled them apart they had next to no oil left in them!
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3345785
My experience with Tein suspension has been a nightmare. :kiss:. They are the stiff-est i've came across. Have since changed them to HKS suspension.
Those with jap spec teins might want to send them to Fulcrum to get them reconditioned when they start to make noises. Fulcrum will probably rebuild them to be more suitable for australian roads.
https://www.sau.com.au/forums/topic/184453-noisy-coilovers/#findComment-3345882
