can any1 do this on my r32 ill even pay them but i am in vic pm me
^^ yehh same wanna get it done badd
shameful plug :P
has a dent on right side needs bog and repaint, refer 2 sig for details.
as far as i've been told for the r32 theres 1.that came with that removable light strip, 2. then one with the "skyline" cut out and 3. the normal one
  • Replies 109
^^ how much would that cost to repair the bar + lights + to get it sprayed black? oh and who cut the skyline out?
nissan did. (altho the panel behind it is just stuck on)
repair =($10-$15 bog from supercheap+ sum sanding) + lights are rare,unsure :S. will need 2 replace at least the broken one of course. get it sprayed black = $3-$60 ($3 d.i.y spray can from bunnings, clean and prep b4 painting) or $60 painter/panel beater
Edited by Dan_J
It's awesome how rare these things are and I have one. But decided to sell it. Some guy paid me $250 for it then wanted a refund. GRRHHHH
http://www.trademe.co.nz/Browse/Listing.aspx?id=145909670
P.S Don't PM me guys, don't want to ship that far lol
Edited by Chang
^^ i know it's not hard, i've shipped a Hicas pump to someone on here before. It's more that i'm just lazy lol
What do you reckon they're worth. I didn't know so stuck up a price, but am gathering alot of interest at current price.
I'll have to take mine of and have a look to see why its not working anymore.
I've got the strip stuck onto the back of my R32 gtst so should be handy enough to get it working again :banana:
I didn't realise these where worth so much :)
its wired up to the brake lights but i chose to wire it up with the wires that would light up when i turn on the lights and not when i brake.. am i making sense here? i dont know how to put it in a shorter and less confusing sentence...
i sprayed the garnish to fit the car color (but it doesnt :banana: ) , cos the garnish is clear and the leds would be too bright, i put some masking tape over the letters, was planning to peel em out after i sprayed the garnish, but when i fitted it on b4 peeling the tape out, it looked good enough. had that 'embossed' look. so was happy leaving the masking tape on :) ..
about the color, anyone know where i can get the exact colors for touch up in a spray can? color is gmg..
In short that'd be the tail lights :)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
