hello,
im in the market for new wheels for my r33 gtr so i need a few questions answered
i prefer somethin with dish
my question is does all four wheels need to be the same size eg width
same tyre size on all four wheels?
or can i use a 18x9.5 wheel up front and 18x10.5 on the rears but with the same size tyre?
what have you guys got on your gtr's?
thankyou!
Your tyres have to be the same width because if they're not, it can stuff up your attessa. I'm not too sure on whether you can run the same width tyres on a different width rim.
Adam surprised at your answer considering you own a GTS4.
The main criteria is the ROLLING DIAMETER/CIRCUMFERENCE has to be the same.
If not the AWD clutch will cook as it will be actuated slightly all the time.
Thats why in a GTR/GTS4 you know if one of your tyres is going flat. ;)
Agreed, pretty sure only the diameters have to be the same.
I am running 265/35R18's at the moment, not sure about rim dimensions.
The rear rims do have a different offset to my fronts, they appear more dished(stick out further) and I am not having any issues.
I've got 255s all round but I doubt you have to have the same width, as im sure with hard cornering or lots of camber, driveway edges, etc... not all of the tyre will be on the ground at the same time. TurboX has the right of it, although I never thought about it until I read this thread...just always made sure my tyres where at correct pressures as its not good regardless to be driving around on a flat tyre.
Cheers!
Gagz
Thats why in a GTR/GTS4 you know if one of your tyres is going flat. :(
I'm only 17 and haven't yet had a chance to experiment. :rofl: Most of the info I give is from what I've read. My bad for giving shit information. :wacko:
It is highly advisable to have same size wheels and same size tyres (lost count of how many times this has been said!). It is possible to have different size tyres, but they will likely be different brand / style between front and back. There's a lot of stuffing around working out and matching rolling diameters.
Same size tyres on different width rims might have different rolling diameters.
The advantage of all rims same size is you can swap front <-> back to even out tyre wear.
The ATTESSA clutch is in the transfer case, on the side of the gearbox.
As long as the larger rolling diameter is on the rear, attessa will not chuck a wobbly. If the smaller rolling diameter is on the rear it will detect it as a loss of traction and attempt to engage.
My car with new 325/45/17's on the front and worn 235/45/17's (although different brands) on the back was getting a surging both on the torque gauge and seat of the pants at highway speeds. Thats all the difference it takes.
james.
Edited by heller44
Depends on your rolling diameter, not the width of the tyre..
Since 95sky's car is running the same sidewall percentage with wider at the back, attessa always sees the back running a bit slower than the front. No problem. It is when you do something like 245/35/18 front and 275/30/18 rear that it will be enough that it may freak.
http://www.miata.net/garage/tirecalc.html
go here and put the two tye sizes in, If the back ends up smaller in diameter than the front, you will have issues.
james.
Edited by heller44
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
