R32 Gtr Bonnet On R32 Gts-t
r32matt
 Share
hey man,
Lights are the same, as long as you have bugeye with GTR grille connectors or the N1 lights
as for the bonnet catch, you can either use a GTR one like above, or get the GTS-t one, move it to the back of the support :D so drill holes behind hte exist holes and move it about 1-2cm furthur back :P did that when I got my GTR fibreglass bonnet, works very well :)
OK thanks!! Seems pretty easy!
Whats a Bugeye? lol
If i have standard R32 Gts-t lights what would I need to buy to make the bonnet work? :rofl:
You can fit a GTR bonnet with any headlight. The only difference would be that some don't have the brackets to hold the grille on. As long as you modify/change your bonnet latch, a GTR bonnet will fit.
i got a genuine GTR Bonnet and Grill painted in white, none of this fibreglass, full alluminium with the mat aswell still on the bonnet
and a genuine grill, painted white n in original plastic
offer the right price n i mite let em go
Where are you located mate?
hey man
i got your PM,
I'll get a pic up tonight when i get home
Basically here's a rundown:
remove current latch
you'll see the two bolt holes, get a drill say a 10mm drill piece, drill straight through the bolt holes to the back of the reinforcement bar, then you move the latch about 1" towards the engine and bolt it to the new holes
you use the bolts inside the engine bay in exactly the opposite way of when you have the latch in it's normal position,
I'll post up the technique and what it looks like tonight
Alright :P here goes, sorry about the crappy pics, must bumper, ligths and other things are off at the moment, because i'm stripping it fora respray
Here are the existing bolt holes, with bolts removed, I drilled through to the rear of these
These are how the bolts sit now, backwards to where they were, with the radiator still fitting in nicely :rofl:
This shows my radiator, if fits with the stadnard one, but that one is a 240sx(180sx) radiator from the states, 55mm thick >_< triple core, best of all if only cost me $220NZD :( plus a $10 top pipe from a commonwhore from stupidcheap auto, very cheap and good upgrade, fully recommend it
do a search for aluminum 240sx radiator on ebay :( and get one
All i had to do was tap a hole for the water temp sender and the thing never even gets over 1/2 way even without hte fan running sitting at idle for 30 minutes :)
Bottom pipe lines up perfectly, goes into existing radiator holes
what it looks like now, see how the bolts are at the back and the catch is about 1"(2.5cm furthur back)
Testing the latch
Clicks closed :) perfect
Test subject - R32 GTR Fibreglass replica bonnet with intake vent and radiator vent
ur a legend mate, ima do this 2moz but i got it holdin down at the moment with proper bonnet pins looks tough as:)
How close does it sit to the top of the standard radiator??
Edited by SLY-dN
  • 1 month later...
sorry for the late reply :S
sits exactly the same as the standard bonnet :P no lower or higher, changing the bolts to the other side doesn't hit the radiator eitehr :D perfectly cheap mod
also if you need a cheap 50mm core radiator, go like the one above, same height, mounting points as the R32, just different top pipe location
 Share
    • So I've been working on the car a fair bit, doing a lot of little things.  Still making slight adjustments to my tune, as the cold weather settles in. I've also had to start dropping boost and tire pressure as the weather gets cooler. It's getting very swirly at highway speeds. I drop to 20psi at 20C and 18psi spring pressure at 10C IAT's. I'm currently on 255 Falcon RT660's, but may look into running 275's next summer. They will fit, but barely. Might have to raise the rear a tad.  I'll start redoing my exhaust Monday, as I have the week off. I currently have an oval center muffler and cannon rear muffler. I've been told more then once from people behind me that my rear bumper is going to catch on fire one day. Seems I blow 5-10 second flames after doing a pull. No clue if that's the WMI, as I've never been able to do that before with other cars. I wanted to angle my tip down a tad so flames are pointed down and away from bumper. I also wanted to take the opportunity to reconfigure my exhaust line. I'm going to move my oval muffler to the rear with a pie cut angled tip and put in a new smaller round muffler in the center. I've rocked cannon mufflers on this car for the last few years and want to transition back the oval muffler look. I've also been looking for a stainless project to try out the new solar flux I bought. I'll post pictures on Monday, should be able to wrap that up in a day.  I'm also picking up another rear subframe this week. I wanted a second so that I could modify one with a gk tech anti squat reduction kit during the winter, and still be able to keep the car a roller so I can back it out of the garage if needed. I will also be caging it this winter. More on that later. Lastly, Speedtek still hasn't given me diddly squat. Every week for the last 4 weeks, they have been saying next week. They told me Friday to expect a shipping label that day to ship my two bad sets of ring and pinions back and nothing. There's definitely been more contact since I started destroying their company any chance I get on Facebook, but it's still just words without action.
    • Have you done a pressure test on your intake/piping? Cleaned your IACV and Cold start valve?
    • Bit of a dump of ones I saw on my trip. I also have a heap from daikoko but that’s technically not  on the street
    • i was thinking that the 2 wires that go to the sub from factory has some sort of preamp like you mentioned and also a lo Pass filter to get just bass. now that will only use 1 channel and that really should be all i need for a sub? if i was trying to put a set of speakers in the back i can understand cutting into the left and right speaker wires. i will try how im talking about doing it and if that is crap i will do it the way of all wires. thanks for the input guys.
    • Challenging mig welding thin Aluminium pipe and trying to fit it in, having to bend and twist, but got there in the end. Fits really well and can easily get a socket wrench in there now to put it on/off. I'm in the middle of another project, so haven't installed the suction pipe yet. I'll post some pictures and results when i do.
