haha that's funny. My stockish RB25DET cuts the fuel around 7000rpm :D but i guess it's A) safety and B)pointless to go harder as the stock turb is outta breath by then anyway.
Does it sound good over 8000rpm? I reckon it would be as angry as a Type R, hopefully angrier with an extra two pistons spinning around.
  • Replies 60
Yeah no point reving them that hard when they are stock.
They sound fair quiet on boost but once it gets up about 6,000 rpm and above you can hear the engine struggling and whining.
But again I haven't rev'd it that hard too many times so haven't taken much noticed.
I'd rather hear it on limiter!! :P
Edited by abu
From what Roy has said im pretty sure his has seen 8500 on numerous occasions!
And its not like his motor is lightly tuned either.
BUt prob wait till he comes in and drops his 2c :D
But i feel the same as well as you guys... I remember going to Launch my car once and i forgot to put it in gear :S
I dont know what it revved to but it did make a odd noise, like not something breaking and not flutter and not my BOV... Motor still seems A-OK though!
Hahaha revving it on idle to 8,000 rpm odd wont cause damage if its just there and back. But constantly holding it there, or under load say in gear it will cause some damage, but depends on the situation I guess, and things such as tune.
Yep also keen to see what Roy has to say. I know he revs his motor hard on occasions but that’s tuned motor. I need more feed back on a stock motor :P
i've hit the limiter a few times. it just cuts out all power. just back off abit and get back on it.
mines a std rb20det auto with std ecu and my safc reads about 300rpm lower then what the tacho reads.
7992 is where my factory limiter was (according to my old R-FIT) So 7,800 sounds about sopt on.
Yeah thats what I thought.
If it kicked in 7,800 rpm that would be awesome!
Edited by abu
Std rb20's with the rev limit raised to 8900 love the limiter all day long.
ps wolf ecus are shit for an rb application.
pfc remap ftw
Any reason why WOLF is shit? Would be keen to hear the explanation behind that.
After market ECU's are only as good as the tuner, that goes for any ECUs including PFC and REMAPs.
8,900 rpm is way to high, maybe if its been modified and tuned.. but still why the fk would you rev it to 8,900 rpm?
Edited by abu
Yep also keen to see what Roy has to say. I know he revs his motor hard on occasions but that’s tuned motor. I need more feed back on a stock motor :rofl:
LOL...my engine is a $600 short motor from EKW, it was built by Nissan and tuned by a built fella. But the motor is std.
As for rev limit, i would stick with about 7,000rpm and i am confident the thing will last a lifetime. If the thing doesnt breathe that well up high and drops off power, then dont rev it...it hurts your acceleration and the engine needlessly
Some thinking of mine about abusing RB20s :wacko:
Dont rev the engine harder then you need to in order to fall into the meaty range of the power band on a gear change. Make sure your fuelling and ignition is on the money at the higher rpms and the engine isnt pinging. Also, make sure you are not getting your water or oil temps too high (water 95deg C and oil 100 deg C) To some that may be low but when i see those temps i tend to back off the motor and drop the revs well back to let it all cool down.
So, that all said. I have used 8,600rpm (According to PFc handset) and 1.5bar of boost in my engine. Its a credit to my tuner and the reliability of a std motor at 260rwkws. I typically run a rev limit of 8,000rpm and around 1.3bar.
You can see in the attached graph which shows rpm that even with a reasonable sized turbo the power does fall off at 7,000rpm
So i am to keep my car's revs between 5,500 and 7,000rpm as it never drops below 240rwkws. So at motorkhanas i bounce off the rev limit a fair bit as i am in 1st. Occasionally in 2nd gear. At the track i generally touch the limiter if its a slow corner and 2nd gear as i need to wait that moment until road speed actually catches up with wheel speed (touch of wheelspin)
But apart from that i generally shift up at around 7,300rpm when into 3rd and 4th gears etc etc. When at Sandown and Winton there are a few corners where if i give 2nd gear hell the cars gearing allows me to avoid a gear change and get great drive / power on exits. So when at Winton and Sandown i will up the rev limit to 8,600rpm and i get damn near it on my 2nd to 3rd shift, occassionally hitting it if i get a bit of wheelspin. But at a place like Phillip island where its all 3rd gear stuff and higher i tend to only rev it to a bit over 7,000rpm before changing gear.
So, yeh they rev nice and handle the revs and boost well. But as i want this motor to last as long as possible so i can find out how much abuse and power it can make ...i do tend to apply some logic to how i drive the thing...though most ppl think im just a butcher :(
This is 8,600rpm (maybe 8,800 cant remember) and 1.3bar
and a lets
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
