Hi all,
I am having a few issues with my R33.
When I plant my foot and rev it to about 5000rpm the car will pop flames like its running REALLY rich and as it continues to rev to 7000rpm the pops happen more and more.
so basicly you know when you back down a gear in a car with a big exhaust and it burbles and pops flames well mine does that but more vigourisly while I am driving it hard.
I leaned it out heaps in the high revs on my SAFC and that seemed to clear it up a little bit but the car started to ping due to being too lean so I had to richen it back up again.
I also notised that my SAFC was displaying 100% air flow at around 5500rpm and onwards... but I didn't think I would be maxing out my air flow meter with the small ammount of mods that I have, any one know what the stock air flow meter is good for?
I am assuming that what is happening is the AFM is reading 100% air flow and the ECU is going ohh crap dump fuel but I just don't understand how I could be maxing the AFM.. I have heard that they are good for atleast 250RWKW and my car is definatly not making that much power but I am running stock ECU with SAFCII.
Any ideas???
Edited by Finny
https://www.sau.com.au/forums/topic/184526-problems-with-r33-gts-t/
Also a friend of mine has an R34GTT and that made 172RWKW on dyno with very little mods and his SAFCII was displaying 98% air flow at the highest which he thought was a little worrying. When I first got my car with stock side mount ect. I could get it up to about 96% when pulling it hard up a hill in 3rd at around 12psi but now I have FMIC and a few other things the car is easilly hitting 100% AFM in 1st gear let alone 3rd.
I really thing the only way I can resulve this is with a PowerFC... which is anoying because its going to cost me heaps to get it tune up as I live in Tas.
Thing is I can't understand why I need a PowerFC when all I have is stock turbo, FMIC, free flowing 3" exhaust from turbo, pod and thats basiclly it I would assume that stock ECU would easily handle thoes mods.
Coil packs seem fine and spark plugs are iridiums gapped at 0.8mm.
Ok so that means Z32 AFM for me but the problem is, I have an SAFC but not a PFC, I assume you can get a Z32 to work with a SAFC but wont that just translate the Z32 signal into a stock AFM signal then feed it to the ECU meaning the limit will still exist due to voltage range??? I don't really understand it that well.
But I assume I need a Z32 AFM and a PFC... so I am looking at about $3000 to fix this one problem :'(
I might as well add some more money to that and get an RB26DETT half cut and do away with the RB25DET :S
Edited by Finny
http://autospeed.com.au/cms/A_2424/article.html
This was in a recent thread. It's a really good idea rather replacing the afm you have a bypass around the afm and tune the safc proportional to the new volume of air flow entering the motor.
Edited by BAMR33
I'm pretty suer a SAFC accomodates the Z32 afm, and can translate the signal to the Factory ECU correctly. So I doubt you'll need a power fc.
But you're going to get a better result with the powerfc anyway. Maybe look into selling your safc and getting a PFC anyway?
did u change ur plugs with ur FMIC? my r33 broad minded persontered like a bitch when i had the wronge plugs in after my FMIC install. and i though cars only shot flames when there's no cat in the exaust. may be wronge but its cheaper to check these b4 buy a PFC.
good luck
Aif
Also make sure it's not just your coilpacks arcing. Take the plastic cover off the top of the engine, drive around hard at night until it's making the noises, then pull over and (carefully) look into the engine to try to see little sparks grounding themselves to the block. If it does it at stationary, it might be easier to recreate.
I know this but what I want to know is say (I dont know the voltage ranges so this is an estimate) stock AFM goes from 0v-5v and 5v is say 500cfm of air now if a Z32 AFM was say 0-5v as well but 5v was 1000cfm then what would happen is if you have a Z32 with a SAFC then when you hit 500zfm the Z32 AFM may only read say 3v but the SAFC converts that to the old AFM singnal so it spits out 5v to the ECU so there for there would be absolutly no difference in cfm limit.
I am just wondering if I am correct in saying this.
ALSO...
AFM bypass, I have known about this for ages but this will also not fix my problem.....
ok I give my self a 50% AFM bypass so that 50% of air is going into the AFM and 50% is bypassing... I set my SAFC to add 50% to the AFM reading. AFM gets to 50% air flow SAFC blows it to 100% air flow and you hit max air flow, You may be able to remove the limit on the AFM but the ECU will still be seeing 100% Air Flow and I doubt that it will have maps for above what the AFM can read so uselss.
Only was I can make this work is by doing this, Getting for example 740cc injectors then doing a 50% AFM bypass and then I wouldn't even need to use my SAFC because the Injectors are pushing 50% more petrol but the AFM is reading 50% less air than its really gettings so that works out perfect. But I think this would screw up your timing etc.
I know some one who has done the AFM bypass as he has a Twin TB NA RB30DE and the AFM only reads on one TB, he also has neerly double sized injectors to match and some SAFC tuning to get it perfect and he only sees around 40% AirFlow even though he is making around 170RWKW.
holy shit, I just read this - this is madness. Your engine will die!
You need a Wideband o2 sensor and also need to know what you are doing!
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
