I NEED
The garnish that sits between the rear quarter windows and the doors
need the plastic that covers the cluster or a broken cluster with plastic cover
The interior panel that goes around the stero air con etc
A skyline steering wheel
Door cards
Let me know wat u have
have money ready to go
luke
0414391972
https://www.sau.com.au/forums/topic/184565-who-is-wrecking-r33/
