Hi guys,
Bought 2 brand new Apexi Pen type turbo timers & found out they cant be fitted to Evo 9's due the the security system! Anyway will fit skylines & other turbo cars just need a harness with cost $15 or $20 off ebay!
Price is $100 for each which is cheap as i paid $120 each just last friday!
Here are the details:
Turbo timers are designed to keep the engine idling after the engine is shut down and ignition key is removed. The purpose is to keep oil running through the turbo to cool down the center housing. This is particularly critical after a hard run, where the turbines can spin at over 200,000 RPM and reach temperatures as high as 900C. If an engine is shut down immediately after a hard run, the turbines may still be spinning without any circulating oil. Extended and repetitive oil coking within the oil lines and center housing could result in clogging problems and damaged turbos.
The A'pex auto timer features a compact interface design (4 x 3/4 x 5/8 inches) with a separate control unit that can be hidden away underneath the dash. The Auto Timer is also the first timer with an integrated air-fuel ratio monitor. The unit reads O2 sensor signal from the ECU and extrapolates and air-fuel ratio value. The Auto Timer can detect the engine load before shutdown and adjusts the idle time accordingly. Finally, the Auto Timer has a safety/security feature that immediately shuts down the engine when the parking brake is released.
In Japan, the Auto Timer is frequently used in normally-aspirated cars. Like turbo engines, normally aspirated engines can benefit from cool-down idling after a hard run. Many have also found it useful for keeping the A/C running on a hot day.
Can post interstate at buyers expense or pick-up
Cheers
Alan
https://www.sau.com.au/forums/topic/184594-apexi-turbo-timers-black/
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
