hey guys, my R33 keeps shaking including the steering wheel only when im doing between 108km - 120km then after that its fine. I just got the car alligned and balanced and it fixed it for the day then its back to its shaking self again after the next day.
any suggestions?
https://www.sau.com.au/forums/topic/184633-wheelcar-shaking-between-108-120kmh/
Check the virtical control arm between the upper and hub for play. The load bearing in there may have play and cause vibration due to wheel instability. You should also check your castor rods to see if the bushes are split and leaking oil. Failing that, I would be looking for a strut failure or leak.
Just a thought but the weights from the wheel balancing hasnt come off has it? Happened to mine and since it fixed itself for the day maybe it came off after the day.
Edited by G_Force
When they did the wheel allignment the bushes were leaking a bit- but they tightened it up and said it was all good.
If all the wheels are balanced, i would be checking the steering rack bushes or check if there is play in the rack ends, ive just a real bad case of the my friends car shaking very violently, found the steering rack bushes were disintergrated and tightening them wouldnt do a thing. You can get these bushes of ebay, pretty cheap, look for d-project bushes. hope that helps
how long has it been happening before balancing? maybe rims wasn't put back on properly. Do you have aftermarket rims? check if the centre hub is the right size, otherwise the rim won't be truely centered, and 5 studs won't be strong enough to keep it centred after driving for some time. it only takes just a few 0.xx mm off the centre to cause vibration. It happened to me when upgrading my stock rims to aftermarket, need to go back to the rim shop to get some centering hubs.
or perhaps the rotors need machining? with my old rotors that fixed the vibration for quite a while (until I swap to 17" rims - then it became the rims' problem).
well if as you say the wheel alignment fixed it then I'd go with the wheel alignment bolt not being tightened up correctly and has come loose after a day returning you to your previous settings. Get it re-aligned at the workshop or at least go back there to tell them the problems back
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 馃槄
    • Try fabricating something like this and install it under the pedals? Not sure if it's legal or not....
    • Even though I have some pretty good (brand) ratchet ringies, I avoid using them to break open tight bolts. A broken ratchet is very annoying.
    • Also, there's always room for 4 or 5 3/8" drive wobble extensions of various lengths so you can operate the ratchet from a better location.
