Getting a 350gt-8 in a few months and my plan is to fit a towbar and pull my old mans boat and my motorbike trailer. Do any of you forum junkies know of any issues that may arrise from putting load on the gearbox? Is it worth updating the trans cooler? And does anyone know the towing capacities....?
Any advice would be great
-Ben
https://www.sau.com.au/forums/topic/184650-towing-with-the-v/
depends on a few factors.
will you have the car loaded up as well (luggage etc?)
the below is for the coupe so adjustment for the sedan will be needed.
454kg for the toe load
and 45kg for the tongue load
don't forget to adjust the tire pressures as well.
The car will almost alway have 3 or 4 people in it when im towing, plus luggage.. Should be fine, it just concerns me that the 8 speed box may Continually slip through gears when im pulling a load. Might have to get some quotes
well its not actually an 8-speed auto, its actually a CVT transmission
i don't know much about them or their ability for towing
for best information, check to see if aussie-delivered CVT cars (such as the nissan murano) have the ability to tow. i can't see it being an issue personally..
  • 9 months later...
  • 2 months later...
oh man
i would not even think about it given no-one seems to be able to fix the boxes
He's right, all the forums for fixing that box are blank. Think about it, isn't it a safer option to use another car? If you break the gearbox on that baby you'll have to buy another one form Japan or another car. Not even insurance can help you if it comes to that.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
