  • Replies 68
well I figure since you drive it hard the dogbox is probably the smart choice for you. should be good fun when it's set up with the ign cut shift too. :P
i wish i was "allowed" to get one too...
ive got an Autronic SM4 with ignition cut shift too, coupled with a straight cut dog box would be heaven.
life is so unfair....or should that be "wife" is so unfair?
Disclaimer: although the above post was made on this account, it is not necessarily Paul that wrote it. Just incase Stacey is reading it.
what problems did you have with the ppg? and what bits needed replacing? did you have an ignition cut on the ecu for gearchanges? and did you use the clutch with it?
once this gearbox is in. it will be 70/30 track/street. thats what lary the laser is for :(
I broke 2 small input shafts, lay shaft bearing and need to replace 2nd gear. No ignition cut. I always double clutch on downshift on the race track and during slow driving around the street
Hey Guys still trying to get used to the box, just a qwuick question. When your just driving around normally(not on the track) do you find that you have to shift slowly and in 2 stages rather than just trying to smash it in like you would when flat out??
As it seems to be wearing in it is becoming a little harder to use around town.
Cheers guys talk soon
Matty
I found the same thing. The delay from shifting in 2 stages allows the gears speeds to match. I find double clutching on upshift (and down shift as well) on the street doesn't produce any noise what so ever during shift.....very gentle and graceful. Flat out driving there is only one joyful way of doing it as R33 racer stated. However I still have occasional trouble with 1-->2nd and often use the clutch for this. Does anyone have any special trick with 1-->2nd?
cool. yeah i would be getting the larger input shaft option. and all brand new bearings. and also will be making a spraybar for inside the gearbox to directly spray oil on each gear. havent quite got it started yet. either using a pump of the tailshaft or an eletric one.
do the straight cut gears suffer from lubrication issues in the gtr casing?
matty
when we are just chugging around, i have found being really forceful with the change is best. If i just lazily put it into gear in most cases it will chatter on the dog gears and feel rather harsh. best to be acertive with it even at slow speeds.
cheers russ cya soon , congrats again mate on the pittsworth win!!
Cheers guys was a good weekend. Yeah i suppose experience with it is the only way to figure it out properly. Im finding that when im just "chugging around" and try changing forcefully it jars my wrist every time as it seems to jump before it engages. How long did it take you to get it into 3rd 1st time everytime?? I keep seeming to either get 1st or 5th lol.
Cheers
Talk soon
Something else to watch out for is oil being pumped out the breather. I run straight cut ppg with redline light weight shock proof oil and i have problems with the oil coming out the breather. Does anyone else have the same problem with there box? I added a longer hose and run it up into the engine bay to the highest point not the best solution but it has stoped losing oil. I think i might have to pull the box down and install a shield where the breather pipe is.
with the breathing thing I know john runs on both diff and gearbox basically an expansion tank. so he runs the breather up to a small tank which is ventilated. the GB oil can be thrown up into this little tank, then drain back into the box. basically just like the radiator expansion tank. seems like a good, simple idea. could be worth a go.
33 racer which oil do you use? If the breather problem can be solved down in the gearbox instead of further up in the pipe we can have a breather that will do what it designed for... What i thinks happening in my box is the light weight shock proof is very sticky and the gears are flicking it up onto the roof of the gearbox then with slight pressure the box create it pushes it up the pipe. Now im not sure if we have enough room above the gears to install something like a baffle to deflet some of the oil away from the breather. Does anyone have a box thats in pieces at the moment to check out if this is possible?
were using the shock proof light i think it is, the blue one which ppg recommended for the box.
We dont have a box in pieces unfortunately, however i reckon the mini catch can with drain back would work well for it.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
