Stillway in Japan make a gear shifter that locks out 1st and might be applicable in this case.
Thanks mate, trying to find the product but not having much luck. Will def buy one! Do you know of any in aus?
Has anyone on here used an Ikeya Formula sequential shifter with a ppg box?
Edited by PJ.
  • Replies 68
Yes, the Ikeya is no good with the dog boxes.
The Stillway shifter works by locking out the gear that you shift up from. ie, 1st to 2nd cant go back into 1st; 2nd to 3rd, cant go back into 2nd; etc etc. This allows you to not miss shifts as you go up through the gears and effectively becomes a 'sequential' H-pattern box. When you want to go back down though the gears, you can do so up lifting the lock ring that is on the Stillway shifter and then engage the lower gears. It is mainly aimed at drag racing so that you don't shift into, say, fifth gear when doing the 2nd to 3rd shift.
I went for a massive fang last night (on a track of course) not using the clutch for both up and downshifting and I'm really loving this box now.
My mechanics put a much firmer relocating spring in the box so it neutralises a lot harder after I pull out of second. I still use the clutch from first to second though as it seems to clunk a bit otherwise. Can't wait to drag it again now, I'm sure there has to be a tenth or two in the gear changes alone compared to the syncro box.
Do they have a hp rating on the helical dog gearsets for a GT-R/GTS-T box?
What 60' and et?
Shocking 1.955 60ft, track was prepped to the max so I needed to turn the anti-lag up a few more psi but didn't have the laptop handy at the time. 10.658 @ 137.60
I bogged every run! Prior to that I ran a 1.69 60ft so next time I go out, it's on!
M/T 255 radials
Edited by PJ.
  • 6 months later...
Im happy to say i fixed my oil being pumped out the breather pipe problem on my ppg gearbox... What i did was add another breather pipe to the inspection plate on the top of the box where you can see the selector plate... I then ran both breathers up to a high point in the engine bay and now have no loss of oil from either pipes no mater how hard its being driven...
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
