I have an r32 gts-t which has lately given me headaches. To cut a long story short, an engine bearing is starting to spin which means death is not far away.
I've spent a lot of hard earned dollars on replacing many bits and pieces and believe that everything is running well except for this issue with the block.
My question is, what do you think is the logical thing to do? I can either sell my car at a giveaway price with all the supporting mods with close to 200rwkw, or replace the rb20 block and head and just transfer all the stuff across to it.
I love my car to bits, but it has been giving me a lot of headaches lately because of this engine. Having this issue lingering in the back of my mind puts me off driving the car when I really should be driving it...cos i enjoy driving it.
I'll admit that I don't have the skill to do a swap myself, but i have some friends who have done swaps on other cars (fwd) who are willing to help.
I want to believe that a swap is a good idea and selling it is a bad idea, but maybe some opinions will straighten out my thinking.
Please help provide some opinions, options and general costs for doing a swap...or not doing it and cutting my losses as it is.
Any constructive opinion is welcome. Thanks!
also, swapping to an rb25 is out of the question for me.
Main mods:
Spitfire coilpacks (new)
HKS 2530
Denso 550cc injectors
Link ECU
Bosch 040
https://www.sau.com.au/forums/topic/184659-replace-the-rb20-or-cut-my-losses/
  • Replies 53
2.5k and a mechanic and your problems will go away. Wrecker motor with 3 month warranty, new belts, pumps etc and all labour performed by someone else. I would expect that you wouldnt be up for much more then $2500, providing you can get a motor for less then $800
if you can do it with friends then even better, just be sure that its done properly
you sound like me when you say that it pisses you off to drive it, knowing there's a fault. i know how it feels!
if you end up selling it and getting another r32/rb20, you're probably going to miss the certain good things about your car.
do the swap. otherwise you have to start from scratch again.
at least if you trust or know the wrecker/seller, you'll have a good investment on a healthier engine, plus spare parts :)
agreed
And...speak to the ppl you actually plan on doing the work. you will only get personal opinions on this forum...noone hear will guarantee your money is being well spent or you are going the best option. :)
I dont know what i am talking about...if i did i would be earning a living from this. Im just a hillbilly who is too tight to spring for a real car so blabber on about RB20s. Its only one persons opinion but i at least try to substantiate it :) More views you get the better informed your decision will be >_<
A friend of mine had the conversion done to his,
There are plenty of room after the conversion too, good for a V-mount intercooler i reckon, also less weight too.
Any advantages?
They say the SR feels more responsive, and can produce just as more power as the RB20?
Any advantages?
Dont know about responsive but all i can see is,
Less weight
SR produce up to 240kw@wheels with stock internal
More parts for SR than RB20 these days.
thanks for the opinions guys.
like the rb25, i probably wouldn't go down the SR20 route. i just want to keep it plain and simple with as little hassles as possible.
are there any workshops that would be recommended to do the work (well) at a reasonable price?
i'll have to give them a call or drop in to talk to them about it first. not fond of being screwed around with anymore car stuff by mechanics.
Less weight
True true!
240rwkw can be done on RB20 too, thing is though RB20 parts aren't as common as SR20, like you said.
I like the SR20, but prefer the RB20.. Everyones different though.
True true!
Offcourse RB is the shit but only from RB25 onward.
Starionturbo (a vic sau member) had an RB25 in his 32gtst a while ago, let me tell you it goes HARD. Only suggested SR because it would be different that's all.
Don't forget the only person that can steer an RB20 FAST and beyon it capability is TROY but no one else :P ! J/K.
just curious why you wouldnt go the rb25 route? there wouldnt be much of a difference of a swapova. stuff is just a bit bigger. i only know rb26 so dont take my word on anything else. just curious
Have you driven an FD RX7?
You'll feel the weight different between the FD and your GTR straight the way.
Hahah its true but, Roy gets mad results lol
I can see Roy lurking around in this therad, your about to get a good answer to why RB20 is the shit! :(
How hard is it to put RB25 in? I got wolf and that so ECU side wouldn't be that hard, just the loom/wiring is the most difficult.
Djemz I think is his forum name, he has an RB25 in his R32. Runs a HKS2535 and E-MANAGE, makes a reliable 240rwkw..
I've talked to him and other people who have been in the car.. Staight out machine.
Edited by abu
LOL...i take insults far better then complements. Snowie?
But point is, i only rate myself as a fair driver. The fact that the car does what it does isnt me, its the fact that a GTSt even with a lowly RB20 can still be a pretty good thing.
one problem you WILL come across at some stage when fitting a 25 is the increase in capacity vs. the vicroad guidelines for motor vehicles. Don't go this route if you don't want troubles with the local constable, unless you plan on getting it fully engineered.
For an easy replacement, I would suggest going down the path of a good condition secondhand motor. Cheapest, easiest option there for sure.
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
