Anyone been playing the downloadable demo on PS3, Its an awesome game, and looks mint on HD LCD.
i was bored the other nite, so i spent like an hour playing it trying to beat the World record time, Managed to beat the citreon (frog Rocket) WR track time by 3 seconds.
If u beat the WR time by anymore than i did, please dont tell me as I consider myself to be a Colin mcrea freak.
P.S Travis pastrana aint no WRC driver.. stick to bikes mate... sorry had to get that out, that guy annoys me.
https://www.sau.com.au/forums/topic/184680-colin-mcrea-dirt-ps3/
  • 3 weeks later...
need advice, love rally games but torn between 2 for the ps3, this one the thread is about CM rally, or is sega rally all that it seems to be?
cheers
I have the full version of Colin McRae Dirt.
Played the demo of Sega Rally.
Sega = TOO ARCADE LIKE...sort of like Ridge Racer but not as extreme.
Colin McRae = BEST f**kING GAME!!!!
I've got it on 360 and it's an excellent game.
The colin mcrae games went a bit crap for a few years but the latest one is awesome.
And the new Sega Rally is really arcadey, but the original was and the 2nd one so if your after some quick arcade fun it would be alright.
Has anyone played Dirt on 360 and ps3? and aer than any noticible differences?
I grabbed the demo of Colin Mcrae and Sega Rally on PS3
I knew straight away without even playin Sega Rally that Dirt would be better... Sure enough it was. Way too arcadey, not even really challenging!
My tip would be to grab a copy of Dirt!
i downloaded this the other night for PC, looks insane, lost of variety in cars too, but the cars don't drift like in the other games
In the other ones you could pretty much drift the whole course which was the best part of them, this one i struggle to get the back out even in the RWD buggy's zz
It kills my PC too even though it's pretty new-ish
  • 5 weeks later...
  • 7 months later...
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
    • That's exactly what I told myself. I'm happy it came out.
    • My bet is there's a fuse somewhere you blew that feeds power to the ECU. Or you've bumped something out behind the dash board.
