was sitting stationary this morning and saw steam come out bonnet, i look down at temp gauge to see it almost in the HOT area... so i like mounted the kerb got out and poped the bonnet.
it spat out the coolant out the overflow, the overflow was empty but not sure about the radiator level.
let it cool down for 5 minutes, started it back up and drove it down road to automasters, they are guna look at it on friday.
does this sounds like a thermostat issue? this is the first problem iv had with the car and its so sudden.
are the rb20 heads strong, surely those few seconds was not enough to warp the head. it started and idled fine afterwards and it didnt shoot straight up to the heat either, even after 3-4min of running.
https://www.sau.com.au/forums/topic/184728-rb20-overheated/
when it cooled down did the radiator have coolant in it? what kind of fan set up do you have? if clutch fan, make sure its not seized, if thermo, make sure they are doing there job well by putting your hand in front of radiator to feel air being pulled through the core at a decent rate rather than a slight breeze. Wouldn't hurt to flush the system and put fresh coolant in as well.
you may have a leak if the overflow was empty and was previously full, unsure whether it may or may not be thermostat. I would check these things first.
Edited by gibbau
https://www.sau.com.au/forums/topic/184728-rb20-overheated/#findComment-3346219
i got a call to be told the water pump is leaking, i contacted the old owner and he asured me it was replaced 15 thousand kms ago...
im going to get them to do a oxygen test on teh coolant to see if its worth replacing or chuck the motor away.
strange.. i couldnt see it, spose that wat sucks about it behind behind covers.
https://www.sau.com.au/forums/topic/184728-rb20-overheated/#findComment-3346370
The rb20 heads are tough as.. :blink:
When I first bought my car years ago I unknowingly (due to a faulty temp sensor) had it running upwards of 120degree's for a whole summer. The temp gauge when the sender was fixed would sit on the H rock solid. And I wondered why it would spit water out in traffic lol.
How the car was fine I still have no idea; it went on to run another 100,000km's before I pulled the motor out; still making great power, excellent compression etc.
https://www.sau.com.au/forums/topic/184728-rb20-overheated/#findComment-3346395
timing belt was done about 15 thousand ago, has a stamp on there saying so anyway. looks to correct by the condition of the belt
by the time i get a tow truck which will be 130 bucks
go to my other house to collect the tools i need to do the job with fuel + the cost of a pump and coolant
may as well get them to do it :P
i was just trying to justify spendn that amount LOL so maybe if someone can tell me its a shit job and it takes days il feel better :unsure:
Edited by BANGN
https://www.sau.com.au/forums/topic/184728-rb20-overheated/#findComment-3346952
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
