ok i just got an upgraded fuel rail for my rb26dett but the problem is the holes on the rail were the injector sits in are too big! do i have to get new injectors that fit? i thought all top feeds are the same diameter(well ones for the rb26 atleast) is there away i can make them work? im so lost! help
https://www.sau.com.au/forums/topic/184734-upgraded-fuel-rail/
Why did you buy a fuel rail?
The stock one if fine for over 400rwkw, and going by all your others threads your trying to do things all as cheap as possible... so this parts makes less sense than some of the others!
this may seem like an obvious question but what size and brand fuel rail did you buy? and what injectors are you trying to put in there?
standard RB26 injectors are 10.5mm.
i really dont know what kind of fuel rail! sorry its just like a generic type! its got 6-an fittings on both side and middle! im using stock rb26dett injectors but they are loose as hell in the hole in the rail! can i just use a bigger o-ring to make it fit? ill try to find it ill post a pic/link
unfortunately that is the problem you get with cheaper generic brand stuff. often they have poor fit and finish and are just generally not always 100% suitable. as for larger 0-rings you may be able to. try some and see if you can get some with the right ID and OD to make it work. but personally I'd just bin the rail and either buy a proper fitting one, or just use the stockie.
r31-thanks for the nice comments! no need for that! its my car/motor and ill do what i want!
So you either are or are not short of a coin.
Either way the ebay add says 2JZ... i mean, that isnt RB26 now is it?
Sell it, use the stock one.
It rude to question someone as to if they're low on cash, its none of your concern. You posted in most of his threads just questioning his intentions instead of providing any help at all.
He said the its the same rail but for a rb26, maybe the supplier simply sent out the wrong part.
No need to post useless comments that people dont want to read, learn to be constructive.
In his threads he has been stating he is trying to go all the cheap options.
Buying a un-proven fuel rail does not fit into this and is risky, and as it turns out... look what happened.
Might pay you to go back over past threads, as it seems you missed the majority.
dude, your missing the point...
your not helping anyone. anyway its not the first time someone has mentioned something about your attitude in people's thread, you didnt get the point then and you wont get it now.
let the thread continue.
Might help the poor guy develop some common sense.
ok the link i posted i was the fuel rail looks like!!! i didnt order that one/ or order it from the seller! it came from a company called bmpc here in america! it came in a box marked for an r32/33/34 so yes its for an rb26dett! i just want to know it there away to make stock injectors work! no need to bash my shallow pockets! i got the part of dirt cheap! just looking for help not bashing!
and another note r31 i will beusing a greddy emanage to run my car so is that good enough for your standards? or am i still to cheap?
If you got it for "Dirt cheap" then no real loss, just sell it on. Just use the stock rail (you wont like the cost of AN fittings to get it running anyway)
I would recommend really researching parts you need to make the power you want. The RB26 Dyno Thread is more then a page of braggin rights. You can browse many setups and get an very good idea of what parts people are using to make what power.
The search box will save you $$$ and ridicule.
Happy tuning :closedeyes:
if u do use the billet rail, u'll find u will end up spending 3x the cost of the rail itself, on braided lines & fittings
also if u do use the billet rail, u'll now need an aftermarket fuel reg.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
