Hey all,
I just managed to get my hands on a 87 200ZR Fairlady.... There are few things that I want to do to it and I need an idea as to what other cars I can get body parts etc off... There isn't alot of info out there on these!
Engine is easy - RB20DET.. eventually it will be RB25 or RB26 :P
Gearbox - also R32
Drive train??? Possibly R32 tailshaft? It runs the R200 diff and thats in good nick so Im not concerned about that!
Body...hmmm... its classed as a Z31 so I am hoping Z31 300ZX... Dave (T04GTR) mentioned that DR30 are interchangable as well.... does anyone have any other ideas?
Cheers,
Anna
https://www.sau.com.au/forums/topic/184739-200zr/
  • 4 months later...
Heya
Ive got a Nissan 200ZR (87) as well. Its the same body as tha Aussie delivered Series 3 300ZX (commonly called the Californian). Trying to get hold of as many people with same cars to help with parts too. Been trying to locate front parkers (as mine are Amber) that are clear/amber from S3 300zx. Drivetrain is pretty easy to source parts for. A lot of Skyline gear is Interchangable. Drop me a PM if you need some parts. Will try keep look at for them and hopefully you can do same.
cheers
https://www.sau.com.au/forums/topic/184739-200zr/#findComment-3584158
  • 1 month later...
Yeah the 200ZR is a fantastic little car, good to see another one out there. If you want any info about them, I know a fair bit about the RB20 redtops, and the Z31/R31 series in general (as heaps of parts are interchangable between the two) also have owned pretty much all the variants of the Z31/R31 series at some stage.
https://www.sau.com.au/forums/topic/184739-200zr/#findComment-3727372
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
    • Ahh yeah, probably not too surprising - nice catch anyway, aside from being a bit of a pain.  I think we've done a bit of wrestling and grinding to make sure all is aligned and clearanced nicely if it seems like a potential ongoing problem.
    • Yes - at ~2500-2700 rpm (ie, about 100-110) it was barking a bit. But I've heard that before. Makes me wonder if I haven't captured the flapper open in the past, but with the circlip still in place it rectified itself. More than once.
    • Ahh one of my favourite things Have experienced that with a couple of aftermarket IWG turbo setups, a hint is (usually?) the exhaust gets a bit rowdier/tinnier under normal driving around as you've effectively lost a muffler you usually have operating when you're lurking around off boost.    When I do road trips in my BMW I often (don't tell anyone I do this...) run it in Eco-Pro mode which turns out to open the wastegate at cruise to keep it working as an NA and maybe a little less pumping loss by having the exhaust have an easier path, never noticed that this is what was happening until I upgraded my dump pipe and starting thinking "Why is my car sounding a bit like it's got an exhaust leak now?" - only to find it go away when I run it in any other mode.   Time to go external gate
