  • Replies 47
Should be:
"Contact Us
Western Sydney International Dragway
Lot 1, Ferrers Road
EASTERN CREEK NSW 2766
Postal Address:
PO Box 6306
WETHERILL PARK DC NSW 1851
Phone: (02) 9672 1320
Fax: (02) 9672 1122
Email: [email protected]"
HOPE IT ISN"T CANCELLED AGAIN FFS.
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3416845
cheers :worship: was pretty happy with the time. almost got kicked out lol
it has
arias pistons
eagle rods etc
260 degree 9.15mm cams
cam gears
HKS 2530's on 19psi
3.5 inch exhaust not cat
pfc
sard 700cc injectors
044 pump
made 346awk on crd dyno
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3418151
Yup nice work, was that time done when u raced against that gunmetal grey gtr that did a 10.8sec?
Crank your boost up, their is more in that :thumbsup:
Edit: The VLT's have got to be the drag car of choice this year, pleeeenty around getting into the 10's :nyaanyaa:
Edited by benm
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419212
Crank your boost up, their is more in that :)
Edit: The VLT's have got to be the drag car of choice this year, pleeeenty around getting into the 10's :P
thanks, nah it was against a white turbo territory which di a 12.8 lol. The gunmetal grey one is DVS32R he did a 10.9 on his second run to end his night
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419398
:) Jeremy did a 10.9.. awesome!
Did Dave head down too (pearly one) ???
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419544
QUOTE(GTshortie @ 18 Oct 2007, 02:27 PM) *
only managed 2 x 12.7 and 2 x 13's couldn't get a clean launch and my trap speed was down for some reason don't know why.
what mph where you doing? Do you have an external gate on that?
Mph was only 110mph for all 4 runs, the previous times i've came down it was always between 112-114mph.
-Either my clutch is going
-Or i need to adjustment my boost controller(haven't since i've added a silicon intake pipe)
External gate? Nope internal w/g
it was the white stock looking r33 gts25t series 2
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419565
yeah he was pretty happy. he was so close last week with an 11.06 but said he had a missfire in the top end which he fixed up through the week.
Nah dave went down last week but not this week. think he did a 13.7 last week
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419579
ah ok, there was another white 33 there with an external gate. Was you boost dropping since last time you went down?
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419584
Cool... Hope to head down in two weeks when I have teh 33 back.. wont have it in time for this Wednesday coming..
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419595
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
