  • Replies 47
Should be:
"Contact Us
Western Sydney International Dragway
Lot 1, Ferrers Road
EASTERN CREEK NSW 2766
Postal Address:
PO Box 6306
WETHERILL PARK DC NSW 1851
Phone: (02) 9672 1320
Fax: (02) 9672 1122
Email: [email protected]"
HOPE IT ISN"T CANCELLED AGAIN FFS.
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3416845
cheers :worship: was pretty happy with the time. almost got kicked out lol
it has
arias pistons
eagle rods etc
260 degree 9.15mm cams
cam gears
HKS 2530's on 19psi
3.5 inch exhaust not cat
pfc
sard 700cc injectors
044 pump
made 346awk on crd dyno
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3418151
Yup nice work, was that time done when u raced against that gunmetal grey gtr that did a 10.8sec?
Crank your boost up, their is more in that :thumbsup:
Edit: The VLT's have got to be the drag car of choice this year, pleeeenty around getting into the 10's :nyaanyaa:
Edited by benm
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419212
Crank your boost up, their is more in that :)
Edit: The VLT's have got to be the drag car of choice this year, pleeeenty around getting into the 10's :P
thanks, nah it was against a white turbo territory which di a 12.8 lol. The gunmetal grey one is DVS32R he did a 10.9 on his second run to end his night
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419398
:) Jeremy did a 10.9.. awesome!
Did Dave head down too (pearly one) ???
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419544
QUOTE(GTshortie @ 18 Oct 2007, 02:27 PM) *
only managed 2 x 12.7 and 2 x 13's couldn't get a clean launch and my trap speed was down for some reason don't know why.
what mph where you doing? Do you have an external gate on that?
Mph was only 110mph for all 4 runs, the previous times i've came down it was always between 112-114mph.
-Either my clutch is going
-Or i need to adjustment my boost controller(haven't since i've added a silicon intake pipe)
External gate? Nope internal w/g
it was the white stock looking r33 gts25t series 2
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419565
yeah he was pretty happy. he was so close last week with an 11.06 but said he had a missfire in the top end which he fixed up through the week.
Nah dave went down last week but not this week. think he did a 13.7 last week
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419579
ah ok, there was another white 33 there with an external gate. Was you boost dropping since last time you went down?
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419584
Cool... Hope to head down in two weeks when I have teh 33 back.. wont have it in time for this Wednesday coming..
https://www.sau.com.au/forums/topic/184754-wsid/page/2/#findComment-3419595
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
