Bass's New Wheels.........
Bass Junky
 Share
Hey ppls.
From my little coming together of industrial screw jacks and my front wheels, and the subsequent hole in both tyre and rim, and the face that I need new rear tyres anyway, Bass is getting new rims.
18x8 and 18x9
The choices are as follows.........
Second hand Volk GT-C, 18x8 set of four, Polished lip, bit of dish. I'd spray the centres in a gloss black with heavy gold flakes.
New Works XD9 in bronze, 18x8 and 18x9. Got some dish tough race look.
Buddy Club P1 Racing II, 18x8 set of four Polished lip, would paint centres same black with gold.
R34 GTR Rims, which I'd also paint the centres black with gold. Forged. GTR Tough.
I'm having a lot of trouble choosing.
$2k is approx spend on wheels.
As you all know, car is R34 GTT in Platinum Silver colour.
Help me SAU, you're my only hope.
BASS OUT
  • Replies 184
Kinda like this, but on a silver R34, and with black centers. So, basically pretty much nothing like the picture below lol
Edited by abu
To look pimp get the GT-C's, although 8" isnt fat enough :)
To be practical get the 34 GT-R rims. Forged
To get the best of both world, XD9s. Race look, brand new and with perfect widths to suit your car :(
Say no to the R34 GTR wheels and GT-C.
Only because i love you will i tell you the rims that i woudl be jealous off...
They are Enkei RPF1 ... awesome lookign wheel when you get into 18s with a nice offset :(
:) I love those wheels. Not a common choice though these days with everyone going Rays
actually i third roy... i remember John Udy the driftor from NZ got em on his drift car here in oz a couple of years back... looked hot as and they were pretty light too
See, these wheels are the 2nd best kept secret of a cool wheel, that you dont see on every Joe Blows car...that is uber light and great quality. I want a set of these wheels for my car...but $$$$. DO IT! They will look the part provided you canb keep the offsets under +30
Guest
 Share
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
    • The manual says a lot about the different ratios requiring different shafts. all the Centers are the same but depending on the ratio, this determines the shafts because different ratios need the center to be offset more or less or right to left.
    • those 2 sets of shafts will not interchange and if you’re lucky you haven’t damaged anything with all your pressing and bashing you said you’ve done
    • Freshly built stroked RB25/28. Motor runs great but consumes a lot more oil then It should. This summer with the heat I was consuming roughly a quart per 1800-2000kms. Now with the cold weather coming in, I'm consuming a quart per 1000kms which is no bueno. I had originally chalked this out to break in taking a little longer then it should, but I'm now around 4000km's on this engine. I think it's fair to say something isn't quite right. Here's the kicker, can't find what's causing it. I've also spoken to my engine builder and Precision Turbo and can't figure it out. Here's my train of thought on possible causes and what I've done.  Precision Turbo - I originally started thinking my oil pressure might be a tad too high for my 6466 Gen2. I took the center cartridge out, and while yes there's signs of oil on the turbine heatshield, it's very moderate. There's also very minor in/out play that concerns me. I sent pictures and videos to precision and they said the residue and in/out play is minimal and they doubt this is the issue. For piece of mind, I went ahead and installed a Turbosmart OPR V2 to bring oil pressure down. Made no difference. Precision is willing to take it in on RMA for an inspection and I'll probably take them up on that offer for peace of mind. BTW. Is it just me or does the turbines inducer's look clipped and not even between each other? I just noticed this now while posting and looking at the picture zoomed in. Might just be the picture...  Rings - Hot compression test and leak down test look good. Compression is 160 +-2psi across the board. I leak down at 16% on cyl 1,2,3,5,6 and 18% on cyl4. Keep in mind I have a snap on leak down tester and they read high (I.E, 15% on my wifes 2018 Sentra with 70000kms). Sparkplugs show minimal oil (Only #4 seems to have a tad). At a quart per 1000km's though, I would be expecting them to be wet. Here's the kicker, I run WMI. I'm thinking what if my compression rings are great, but I have an oil control ring issue on cyl4 and my WMI is steam cleaning the pistons and sparkplugs? I can still see the "Spool" logo on top of my CP pistons. The only time I see smoke out of the exhaust is in the high rpm/load range. So far, this is my main culprit. I'll probably turn off my WMI and go out with the car at spring pressure tomorrow and repull the plugs. Other thing that's strange though is that I have never seen any oil in my catch can. Thing is still dry after 4000kms. Cyl1 - Left, Cyl6 - Right. Valve seals - They're new and I would expect oil consumption on idle, first cold start or during decel. None of which is happening.  Crankcase pressure - I have 2x 10an valve cover lines to a vented catch can. Head drain and opened up internal oil drain paths. I also don't run E85. I've never seen any oil in my catch can. Doubtful this is causing any issues.  Rear main seal - I have no visible leaks, but figured maybe it was my rear main seal. After now having added 2-3 quarts, I would expect oil to leak out the bottom drain channel and/or my clutch to be slipping.  Let me know your thoughts. With winter coming and taking the car off the road until spring, I'm fine with pulling the motor apart but I would hate to take it all apart and the turbo was the issue in the end.
    • Actually, the best option is probably to get some of the stronger aftermarket driveshafts that have both the 5x1 and 3x2 pattern on them, so OP can do whatever the hell OP likes with the diff in the future and not have all this angst. I posted a link to them sometime in the last 2 weeks, I'm sure.
