Cusco Strut Brace R33 $100
By soviet_merlin · Posted
I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it -
I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down. I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far. Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
