  • Replies 90
the driver was hitting the limiter before he took off and creeped up forward... then the official sort of lost it and told him to move back... then he revved dumped like he just stole the gtr went left right left right until it looked like he touched the brakes and ended up smacking the rear end mostly on the other side.. maybe he shit himself and got nervous on the track :kiss: does insurance pay for LEGAL drag racing...
and btw CRAKED why werent u racing ur car!.. remember i was going to swap u the bonnet and boot at safs.. i own that white r33.... saw ur car in the car park looking lonley.. shouldve been on the track champ!
Insurance will not cover the damage even though he asked the question of the officials at WSID. :kiss:
The official didn't lose it at him at all, btw. He directed him to roll back through the beams as he had crossed them with his front wheels.
lol, from up top the official looked frustrated because people dont realise that they have a certain mark where they have to stop, thus why the chrismas trees have the 2 top lights that tell u to stop, they should have a sign that displays STOP WHEN THE 2 LIGHTS FLASH or something,
and i think it would be awesome if they had a big screen tv with replay action :kiss:
yeah big screen action reply would be a winner. considering each race only lasts 12 seconds or so and it takes a minute or two between runs some nice replays would be cool.
Hate to say it but this tool deserved what he got....
Before even entering the water area he was bouncing off the limiter for easily 10sec, then the official says oi u arent even in the water so he drives straight through the water and gives it another bounce off the limiter just incase he forget where the redline was.
Then he throws it in reverse to backup to the water but realises its 4wd so wouldnt do a burnout anyway so heads towards the line. Stops a full car length short and bounces on the limiter again ready for the green light. Starter official motions him forward and he rolls straight past the line, then reverses back and slowly rolls forward again whilst sitting on the limiter again.
The starter did his usual pissed off start by not waiting until both cars were set (gtr was still rolling) and soon as the 2nd pre-stage light is up he hits the button and the gtr driver decides to let the clutch out. Does a few left to rights and throws on too much opposite lock, front wheels bite and send him sideways towards the opponents wall (whom would have been shitting himself as much as the gtr driver) and takes out his rear end.
No not even 4wd will save dickheads.
:blink:
Edited by benm
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
