  • Replies 104
actually it (aerial) had a power led lead on the stereo, which is what "I" hooked up, it was my nooby to jap wiring stereo install. I cant remember exactly it was aggges ago but in the manual it said for elec aerials use this wire, which is what I did. When my switch is selected as down the aerial comes up half way when stereo is on and if i switch it up it goes up to full height. No matter what it always goes up half way if the stereo is on. Im going to install the leds into my dash and a few other bits an pieces i,e, custom mock up panel for my temp guages in the din area so ill have a look and disconnect the wire and see if the aerial only works on the swtch. Pretty sure I tested this wayback when but it didnt move.. memory doesnt completely recall. Guess il find out again anyways.
Edited by gts-4 dreamer
I've always thought boot space in R33s is pretty shocking for a car that size
i thought the boot space was decent considering there's plenty of leg room for the rear passengers, compared to 180's and supra which have shit all passenger leg room
the cup holder in the VP commodore that is there but NOT useable.
its in the front centre arm rest box to put stuff in thingy and you have to cut out a hole and re position the leather to get to it... i think they used the same arm rests for the luxury models.
it was not even an option
how about d/s window controls in the 32gtr, when the window's down any water on the roof pours into the switches? yeah!
hey nissanskyrice, go see supercheap. they have a headlight controller that turns your lights off with ignition,
plus has light sensor that works really well. should be standard in all cars tho...
Awesome. Going to stupid cheap thisarvo then. where does it hook up? under the dash or in the engine bay? i have to pull my dash apart again after installing my stereo on the weekend because i apparently unhooked the power to my turbo timer while i was at it :)
nissan head office circa 1988
ok guys, so we're gonna build a twin turbo awd v8 crushing monster.... something that can easily be modified to make 11ty billion killowatts...
first things first... where are we gonna put the cup holder?
lots and lotsa stuff
but, on Nissans, apart from the cursed filter location on GT-R's, the key release button. but you do get used to it after a while i guess
LOL I'm sure you can fix that some how? My ariel only goes up when I have the radio on, not the mp3 player :worship:
beeping everytime i put it in reverse,leave a door open or leave the light on just for a sec so i can see the f**king keyhole to my front door.
seriously its the most anoying thing i have ever came across. beep beep beep its like owning a f**king truck.
i will settle down now.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
