How do I know the right profile? lol
or will they know whats best?
Right profile tyre means diameter of your new wheel + tyre is equal to the diameter of your old wheel + tyre.
for that size i am guessing a std offset so about +20 so i guess....talk to the dealer.
and a 7" wide rim with a 40 profile.....so 215 40 18
something like that.
be better putting 17's on mate can have a wider wheel then.
How can i really tell? lol
Like what would be a max size for the R32? I have standard rims on it at the moment. Would be so annoying if I bought some and they were to big.......
Just use the offset calculator. Put in the specs of the wheels you have on at the moment and the specs of the wheels you would want. It'll tell you how much it will stick out/in from what you've got now. You can decide from that. It's just a guide though, it won't tell you whether or not it'll rub :wub:
Your Car looks really Nice! Paint looks really good on it still!
Should be getting money this week for Mags!!! Gonna get 18inch and get my car lowered.
Also gonna get tinting and redo my interior. Need to buy new vents and some other console parts....
I wanna get my R32 looking new again and smooth but also look sweet!
I have a few scratches in the roof and a big one on the rear bumper..... Would touch up paint fix this? Or does touch up paint look dodgy?
Anyone with ideas on what to buy to make my R32 look awesome, let me know!! I also want to change my tacho lights to blue, but i heard you need to take out the whole dash?? seems like a mission..... lol
"This isnt a pic of my car but my car looks exactly the same but with standard R32 Mags...."
Honestly, don't get any of those cheap, poor quality wheels. Go for the wheels which are Japanese designed. Rays Engineering wheels for example. Gun metal GT-C's would look good on a silver car.
I'm assuming you got those pics from tempetyres or something.
Edited by adam-__-
Dont like the rims you posted up, because I dont like chrome :mellow: Go for gunmetal or something. And if you dont have around 5 grand lying around dont consider Jap wheels.... Fricken expensive! but look awsome, I would just get some 1,500 dollar rims if I were you. (unless you have 5k)
You don't HAVE to go with new Jap wheels that cost $5k. You can pick up a decent set of Jap designed wheels for ~$2k.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
