Hey guys, my mate is buying a Vl Turbo with Rb20det.
It has a few mods (fmic, exhaust, boost), nothing over the top, and runs a Wolf 3d ecu.
From what I've read it's a plug n play unit.
What I'd like to know is if it plugs into my harness, will it run (i know not perfect until its tuned) and is there any difference between the vl rb20 and r32 rb20?
How much do these go for 2nd hand?
VL didnt come with a rb20det did it?
When they put the rb20into it depending if they used the rb20det harnes or the original one for the rb30 the plugs might be different not sure not a holden type of guy.
But if its tuned for his, and plugs straight into yours should work pretty well, as long sa you have pretty much the same mods as your mates car.
Basically if the VL is running a RB20DET motor, which would be out of an R32 or CEFIRO most likely.
To run the RB20DET its most likely running the RB20DET loom, which would mean that the WOLF would most likely be a plug and play unit suited to RB20 loom.
I also have a WOLF plug and play which is suited to RB20/25, as the loom plugs are the same?
I have also seen LINK ECU's which plug into RB20/25/30 looms.
It would be safe to assume that it would plug into your R32, but would just require a retune.
Thanks guys, I knew they werent factory lol...
Just gotta see how much he wants.
I just bought a plug and play WOLF3d unit for RB20/25, send me a PM and I will give you some details and pricing.
Edited by abu
Any Wolf plugin ECU can run any engine you want.Any good tuner can setup the software and if needed swap over wires etc.
I fitted an R33 GTS Wolf plugin to 13B Mazda using the nissan plug and rewiring.If its V500 then its even easyer.Ring Robbie at Wolf for help.
Thats very interesting!
Will have to keep that in mind for future references.
Thats the good thing with WOLF plug and play unit. Even though they are plug and play, they don't automatically default back to a base map when disconnected, for instance to a RB20DET map.
I think the old MICROTECH'S (MT8?), when disconnected from power for a period of time when default back to the base map. If you wanted to change that base map the unit had to go to MICROTECH to get reprogrammed!
NZ VL's had a RB20E in them.
there meant to be great to drive!
I hear some cuzzy bro nearly got his up to 90 a few years back!
Edited by joeyjoejoejuniorshabadoo
