Can any one direct me or advise on the mounting of the rear bar to attach the chute to please?
I have been looking at the car and where the rear bumber bar comes out looks a logical place to me. would still like to see some close up pics of the way some people have set them up if possible.
Thanks
https://www.sau.com.au/forums/topic/184898-drag-r32-gtr-chute-mounting/
most i've seen mount the bar for the chute mount to the tow hooks.
yep , thats what i have seen , but only passing buy before it was my turn to do so , so i haven't really had a proper look.
Wish i could get a close up of what other people may have done?
Thanks for you input Beer Baron
That looks tidy, and thanks for your input.
May i ask whos car rhat is because those rims look onteresting as i want o run same diameter fronts as the back but a narrower tyre width, would you know how i could contact this persaon at all - or is it yours ?
Cheers
Dave
  • 5 weeks later...
Hey gents-
thatnks very much for your in put and yes it has helped - very differant from the way i ended up doing it - but a another bit of information for fellow drag gtr members.
Cheers.
Dont know if this photos will help you.
Keith
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
