i have a r33 gtst. do u think its worth getting coilovers instead of normal kingsprings
i was quoted $400 for kingsprings+labour..but im thinking if i get adjustable coilovers it will save me trouble having to replace them when i get canaried.
i found this link of coilovers
http://www.raceinspired.com/pc-8734-20-d2-...-1995-1998.aspx
what do use think,,i cant decide lol
anyone got experience, or know which would be more worth it
thx
https://www.sau.com.au/forums/topic/184908-should-i-get-coilovers/
definantly get coilovers, maybe not the ones you have linked, all i can say is get what you pay for
why is it more worth it though?
is this because u can adjust it really low and looks better,,or because it performs better.
i dont really care about handling because im happy with the handling my car has already and thats just stock springs.
Yes.
I made the mistake of just buying dampers, thinking I could get springs later. In the end, I ended up getting coilovers as it was hard to find springs at the exact rate and height I wanted, to match the dampers and my desired ride height.
But if you change your suspension components your handling characteristics change. Putting in aftermarket suspension won't necessarily make your car handle better. Putting in heavily lowered springs by themselves can, and frequently does, make the car handle worse.
This is not to suggest that coilovers are only for track use, but if you're only doing it to lower your car, it's probably a waste of money as springs and shocks would be cheaper and probably give you a better ride for street driving. The only advantage to coilovers is the adjustability factor and if you're not 'bothered about performance' you may as well go for a properly matched spring/shock combination and save some coin.
Edited by baron25
I take my car to the track now and then, and I like a rigid feeling suspension... so I'm running a stiffer spring and adjustable dampening strut (street and track)... I've also lowered the car about an inch. If you know the right setting and you don't want to change it, there's no reason in the world to get adjustable coilovers (and technically a spring over a strut is a coilover, as its a spring "coil over" a strut).
If you're not the type of person that needs his suspension adjusted every month for different tracks etc then there's no reason why you'd need em. I find most people do it just to keep up with the Jones'. The added benefit of staying on spring n strut setups is that its legal, adjustable coilovers are a bit tricky to make legal due to their adjustability.
That said finding the suspension setup that's just right can be difficult at first, talk to a very good suspension shop and they should be able to sort you out.
I would have to agree with funky. Only thing is if you get the kings springs you will find that they will bottom out quite easily on things like speedbumps with stock shocks.
I'm running kings lows with stock gtr shocks at the moment, was advised before I put them in that it might be an issue but as usual had to learn the hard way. Looking at just replacing the shock with a set of koni or bilstein as the spring setup I quite like.
James.
Edited by heller44
i dont realy care about track use,,,the only reason i want adjustablity is so i can easily adjust it when i got canaried. if i get kingsprings i have to pay extra labour in taking the springs off and replacing the stocks,,then changing them back after i get cleared. such a hassle
hey mate if i was you i will either get Coilover or the package from Sydneykid.
the reason is that the ride with just spring will change. It is accually becomes bad, and when driving above the limits
especially in a high preformance car you need handling and i know it is not track
Also most KIDS who have accidents and die on these road are because they have crap suspension.
Try Driving on the hume highway (bass hill) with just king springs........Trust me kidney Failure.
Ummm.... just playing devil's advocate here, but exactly why are you planning on a defect? Why not just go legal? It still costs money to get a defect cleared, and chances are they'll find other things to be fixed for the RWC too.
Hit the nail on the head there, which is why you don't buy just springs - you need the matched shocks
go the SK package.
well if you plan to get canaried then you shouldn't get adjustable coilovers as they're a defectable item, even if they're set to a legal ride height. to clear this you need to take the whole strut out and put standard ones in anyway. So either way you'll have to do it :laugh:
Since you are getting springs and shocks, I would really strongly suggest the sydneykid bilstein spring and shock packages in the groupbuy section, they are matched nicely valving and spring weight for your car, as well as having circlip height adjustment. If you can get ahold of it.
Value for money mate.
king springs, plus the cost of a set of bilsteins or koni's to match will set you back the same amount of a bit more and still be not as nice to drive.
personal opinion though.
james.
(I've got kings lows and going koni's very soon)
Mate i dunno where you got your information from
but when coilover are set to a legal height they are not defectable
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
