Yes it's the gear stick and not little junior :domokun:
I have a R34 RB25DET gearbox with helical dog gears and the gear stick partially popped out of the selector rail twice, while still retained by the circlip. This gearbox was at another workshop, long time ago, where a GTR gear stick was accidentally installed....and it was replaced ...or so I've been told, with a RB25 gear stick. I am not sure from which RB25DET model the stick came from either. It's a bit weird that it popped out of its place and made it very difficult to select 2nd, 4th and reverse gear....made a workshop think I bent a selector fork and wanted to do surgery on the box... until I went to the shop today, pulled the gear stick out and reinstalled it, and everything is fine :laughing-smiley-014:
Is there a difference in the stick or the retaining plastic below the circlip between the GTR and GTS-t or between different RB25 models (R32/33/34)?
should work as i fit GTR shifters to all my cars be it Rb or SR boxes (6 spd is only one that wonk work) check the rubber surround is not on backwards as it puts pressure on the shifter which can pull it out of gear and make it hard to select.... ive seen this plenty of times on nissans.
