Hey peoples,
ok so i have a few issues im concerned with.
They include:
1. i have an exedy heavy duty on my r33 gtst 93 model.... and every time i engage the clutch to take off in first or just push it in neutral... if i slowly release.. it sqeaks like crazy... i've tried spraying some rp7 or wd40 on the join on the pedal in the cabin, it does help, but only for a short time. any advice on fixing this would be appreciated.
2. My clutch pedal doesn't seem all that responsive under my foot, when i release it, the pedal doesn't spring up immediately, it seems to take its time, it seems soft.
3. When i try putting my gearstick into gear, it doesn't grind, the problem im having is physically pushing my gearstick into gear. i'm borderline using two hands to force it into first gear position. its like it just wont fit. i have to slam my foot down on the clutch pedal to be able to force it in. once its in though, moving through the other gears isn't nearly as hard. just feels very stiff.
I have had a clutch that was slipping in the past, and when that happened, i could easily put it into gear positions but it would almost always grind no matter how well i tried to change gears. Its not doing anything like that this time.
It wasn't actually that long ago that i had my clutch replaced with an exedy heavy duty. had my flywheel machined at the same time. I dont really thrash my car, only drive it on weekends, i'd be surprised if it was buggered all ready.
thanks for any help you can give me,
Simon
Edited by GuestyR33
https://www.sau.com.au/forums/topic/184924-help-please/
Ok really need help...
my clutch pedal seems to have no responsiveness under my foot, doesn't spring back when i release it.
seems sloppy.
when my car is on i physically cant force the gearstick into gear. when its off it works beautifully.
i have flushed and replaced my gearbox oil, seemed to help the stiffness in the gearstick but only lasted two days.
now it seems to have seized but only when the car is on.
CAN ANYBODY OFFER ADVICE???
cheers
Guesty
https://www.sau.com.au/forums/topic/184924-help-please/#findComment-3357842
Hey mate, sounds like you have the exact problem i have, it started few weeks ago so i stopped driving my car until could get it looked at, took it to a workshop, they adjusted the clutch pedal out, problem solved! only problem is it's come back again so i'm taking it back tomorrow, will let you know how i go
https://www.sau.com.au/forums/topic/184924-help-please/#findComment-3370617
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
