hey guys i have a set of brembo calipers fo sale which i was going to use on my nissan stagea that i have just sold so they are of no use to me anymore maybe somebody here my be able to use them
$2500
im in sydney
0448 101 001
https://www.sau.com.au/forums/topic/184941-brembos-for-sale/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
