how ya going people?
now im in the market for some bushes for my gtr but there are just so many brands out there now offereing the lot! so i was just wondering what everyones opinions on the different brands would be.
yellow being whiteline, blue being noltec, unsure the name of the red ones. and then the nismo items
who has used what? and what were they like compared to the standard ones.
i like the look of the nismo ones but they are fairly dear compared to the rest.
the car will remain a street car, with lower coilovers and big wheels if this will effect the choice
well thanks for the help, James
https://www.sau.com.au/forums/topic/184949-bush-selection/
well all of the nolethene bushes are pretty much the same, whiteline, noltec and superwhatever. they are a fair bit harder than standard but very good price
nissan and nismo bushes are more appropriate for a raod car but far cheaper. the nismo bushes are nowhere near as hard as the nolethene ones.
https://www.sau.com.au/forums/topic/184949-bush-selection/#findComment-3349493
Nissan/nismo are generally speaking rubber nismo normaly harder rubber
nolethane etc. are urethane generally harderish than rubber
color is just a dye though urethane is available in a variety of hardness's (durometer) too, to my knowledge none of the brands advertise the durometer they use?
Not entirely skyline related but have found that things like body to chassis bushings go rubber, real chassis like a 4WD I mean, for comfort
If its a bush that holds steering angles etc urethane, especially for performance applications ie. Skylines
Just my 2c
https://www.sau.com.au/forums/topic/184949-bush-selection/#findComment-3352877
i just did my front bushes in my skyline. i got super pro "blue" apparently they mainfacture the whitleine stuff for them. i took out my whiteline bushes "only 1yr old" in comparison the super pro was a little bit firmer than the whitlelines. so far they feel good and no noises. As far as other brands Ive heard stories about nolathane bushes decaying quickly but i cant comment first hand.
https://www.sau.com.au/forums/topic/184949-bush-selection/#findComment-3356141
i used to work for noltec.
they make good quality stuff. and they should tell you what hardness they are when buying them.
from what i remember they have 70 and 8 durometer...
personally i think that superpro are the best. and nolathane are junk
https://www.sau.com.au/forums/topic/184949-bush-selection/#findComment-3359205
Anyone had problems with whiteline bush's started to install my group buy camber bush's for the rear and one of the bush's was actually cracked about 80-90% through before I even opened the packet. Pissed, now I gotta chase down some more parts and pull it all apart again
Maybe it wont be so hard the second time :D
https://www.sau.com.au/forums/topic/184949-bush-selection/#findComment-3360238
My brother is a mechanic and he recently attended a 'trade night' where they had someone from nolathane explain how the company has had a rethink and now their bushes are using a new softer urathane that wears better and is better for NVH issues.
https://www.sau.com.au/forums/topic/184949-bush-selection/#findComment-3368424
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
