Hey guys,
just bought a profec b 2 boost controller and installed it yesterday.
just need to know what to do with the vac line that went from the stock solenoid to the black pipe
that comes from the recirculation valve.
do i just block it off? what's it for?
any help would be appreciated.
cheers
doobs
https://www.sau.com.au/forums/topic/184970-another-profec-b-2-question/
Actually, dynos are no use really for setting boost controls as they don't provide real world conditions and take alot of time and therefore money to get it anywhere near tuned for the road. You would be better to go to a quiet road and sit in the passenger seat and get your friend to load it up, each time tweaking the settings.
And yeah just block off that vac line, I put a screw in it that was slightly too big so it is tight, then i sealed it with silicone and doubled the hose back on itself and cable tied it near the crimp.
Hope that helps
If your a dumb arse, you might want to get somebody else to tune it, u can stand on the side of the road with one of those old school grid iron helmets on, watching lol. Just kidding mate, I tried doing it on my own once when I first got it, NOT a good idea. Possible the dumbest thing I have ever done in fact, I almost had a head on! I was just sooooooo sooooooooooo lucky the other driver wasn't some dumb idiot like me , but then again you don't expect traffic at 4 am on a week night in an industrial area.
Fair point ardie. i might just wear an icecream container on my head instead,
it's not like i've got much to protect. hehe
i got a mate who's looking to get a profec for his GTI-R so
he can help.
lol. nah i've been using the peak and last boost screen to help me tune it.
BAHAHAHA ice cream container, thats gold, so using that on the misses next time she does something stupid.
As for using peak and last, you wont be able to track how the solenoid reacts throughout the rev range and to the various boost loadings. I've installed and helped set up 6 or so of these including whacking one on a 380awkw GTR and every time I do it the same way: late night, industrial area and friend booting it while I tweak it.
Also, just out of curiosity, where are you getting the boost lines from?
If your mates looking at getting one, I'm going to have one come into my possession within the next couple weeks, if interested in it let me know
Edited by ardie
hey ardie,
my mate is interested. can you pm pricing and postage. i'm located in NSW.
cheers mate
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
