Hi guys.I'm new to this forum and just interested in joining up with SAU.But is there any chance I'd become a member in less then 3 weeks?If anyone could help me out that would be great
Cheers
Moe
huh??????? :P:(:):D:mellow:
what are you on?
https://www.sau.com.au/forums/topic/185034-want-to-join-up/#findComment-3349753
As in the car club? I know NSW and VIC have CAMS affiliation. I assume QLD and Perth do as well.
If you are wanting to join up and get a CAMS licence sorted for a track day in 3 weeks...and in Victoria. Then easy, shoot me your contact number and we can get it sorted
https://www.sau.com.au/forums/topic/185034-want-to-join-up/#findComment-3349768
yeah they don't.. and I was wondering about that.. do they not have any insurance for their cruises?
cruises are organized informally by carpark cruisers...
qld doesnt have a really big circuit racing base... everyone seems happy to cruise down to the local carpark and chat for a few minutes, and then shuffle off to the next carpark.
almost as boring as QR
https://www.sau.com.au/forums/topic/185034-want-to-join-up/#findComment-3351427
Not everyone Eug, not everyone. I'm surprised you find QR boring.......are you perhaps not going hard enough :wave:
https://www.sau.com.au/forums/topic/185034-want-to-join-up/#findComment-3363579
Not everyone Eug, not everyone. I'm surprised you find QR boring.......are you perhaps not going hard enough :thumbsup:
quite possibly jay, it's such a power demanding track though. i prefer more technical stuff like motorkhanas and hill climbs, going to try my hand at street sprints next year. a bit of this, a bit of that, as long as it's fun.
and i reckon it's boring in a sense and especially compared to sweet tracks like darlington and lakeside which just sit there growing grass.
https://www.sau.com.au/forums/topic/185034-want-to-join-up/#findComment-3366122
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
