hey,
just a quicky :blink: just wondering how much boost an rb20 turbo can hold safely, im running 12psi through mine but dont want to go anymore cause i have heard lots of stories of ceramic turbos shattering and getting sucked back into the combustion chamber.
should i maybe turn it back down to 10psi till i buy an rb25 turbo or can i leave it at 12 for a while????
Cheers
Matt
https://www.sau.com.au/forums/topic/185039-rb20-turbo-question/
i have sitting next to me a peice of my friends r32 turbo compressor wheel which shot out through his exhaust.
He was running 15psi + flutter, did a couple of drag runs and bang pop.
I think safe boost level is 13-14psi although quite a few people run at 15psi.
Cheers
you can get away with running 14psi on the rb20's most of the time, but it's best to get it on the dyno if you do to see if it's running lean.
yeah i haven't put my dump pipe on yet so i might wait till i put it on before i turn it up anymore i also want to get a dyno test done but i think ill wait till the next dyno day
  • 2 months later...
I'm running 14-15psi but my engine and turbo are low km's. Does it fine, no probs at all. One of my mates has also run his for over a yr at 14-15psi no probs. Wow, even if a turbo lets go after 2 years thats a huge total cost of like $80 a year for a lot more fun. 11-12 is safe as (If it lets go ure turbo is average anyhow) but i'd run 14psi and no be a b!tch.
Cheers
i'm running 12.5 and havn't had any problems. i hear 12 is safe and 14 is pushing the limit but this is just heresay. i guess it also depends on your driving style, how you maintain your car, and how many km the turbo has done. just make sure you give it enough time to cool down after a hard run and keep it out of high boost in the heat.
I'm just going to add my bit to the above - which are all good opinions. However, I can see you really want a definitive answer. So:
It actually comes down to each car. Now you ask what part? Well, its the whole thing, including the driver!!!!!!! I've developed a simplified formula for you:
The second page got beer spilt on it so I decided just to skip to the last equation:
RB20DET ~ 10-15psi.
Hope it helped :laughing-smiley-014:
dude if your gonna upgrade then I would go a 2530 or 2510...maybe something from trust. The R33 turbo is an improvement over the RB20 as it has a larger wastegate..but its still ceramic...I had a 2510 on my RB20 and it ran beautiful at 16 pounds..If you are gonna go to all the trouble of changing dump pipes then while you are there change all the water and oil lines with brand new ones.They are a nasty thing to change at the best of times, specially that water hose around the back of the engine, we had to drop the starter motor to get to that one...
when i got my 32 it was running stock boost, seemed fairly quick for the first few weeks as its my first turbo and wasnt used to the power change when it hit into boost. Got bored of it so had it dyno'd at hyperdrive to check a few things out and the guy asked me if i wanted to turn it up a bit, i said yes of course :P it is now running 13psi on the high boost setting and has been fine, mind you i only turn it up when i want to give it a bit of a boot. I also only have cat back exhaust and he said it should be fine as long as you dont boot it every day to work on the highway.
got a question of my own, im getting the dump pipe fitted soon and going for a bigger turbo, ive heard the rb25 runs well but want a bit more of an upgrade, any ideas of whats a good turbo upgrade to get?
cheers
I hammered my RB20 turbo at 14psi everyday, and again with the 25 turbo at 12psi. No problems whatsoever ;)
Then I got sick of no bottom end and having to give it 3k and drop the clutch to take a gap in traffic.. RB30 FTW!
lol where'd you get that idea from?
The wastegates are physically the same size.
http://www.skylinesaustralia.com/forums/Sl...20&start=20
look at the pictures
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
