hey,
just a quicky :blink: just wondering how much boost an rb20 turbo can hold safely, im running 12psi through mine but dont want to go anymore cause i have heard lots of stories of ceramic turbos shattering and getting sucked back into the combustion chamber.
should i maybe turn it back down to 10psi till i buy an rb25 turbo or can i leave it at 12 for a while????
Cheers
Matt
https://www.sau.com.au/forums/topic/185039-rb20-turbo-question/
i have sitting next to me a peice of my friends r32 turbo compressor wheel which shot out through his exhaust.
He was running 15psi + flutter, did a couple of drag runs and bang pop.
I think safe boost level is 13-14psi although quite a few people run at 15psi.
Cheers
you can get away with running 14psi on the rb20's most of the time, but it's best to get it on the dyno if you do to see if it's running lean.
yeah i haven't put my dump pipe on yet so i might wait till i put it on before i turn it up anymore i also want to get a dyno test done but i think ill wait till the next dyno day
  • 2 months later...
I'm running 14-15psi but my engine and turbo are low km's. Does it fine, no probs at all. One of my mates has also run his for over a yr at 14-15psi no probs. Wow, even if a turbo lets go after 2 years thats a huge total cost of like $80 a year for a lot more fun. 11-12 is safe as (If it lets go ure turbo is average anyhow) but i'd run 14psi and no be a b!tch.
Cheers
i'm running 12.5 and havn't had any problems. i hear 12 is safe and 14 is pushing the limit but this is just heresay. i guess it also depends on your driving style, how you maintain your car, and how many km the turbo has done. just make sure you give it enough time to cool down after a hard run and keep it out of high boost in the heat.
I'm just going to add my bit to the above - which are all good opinions. However, I can see you really want a definitive answer. So:
It actually comes down to each car. Now you ask what part? Well, its the whole thing, including the driver!!!!!!! I've developed a simplified formula for you:
The second page got beer spilt on it so I decided just to skip to the last equation:
RB20DET ~ 10-15psi.
Hope it helped :laughing-smiley-014:
dude if your gonna upgrade then I would go a 2530 or 2510...maybe something from trust. The R33 turbo is an improvement over the RB20 as it has a larger wastegate..but its still ceramic...I had a 2510 on my RB20 and it ran beautiful at 16 pounds..If you are gonna go to all the trouble of changing dump pipes then while you are there change all the water and oil lines with brand new ones.They are a nasty thing to change at the best of times, specially that water hose around the back of the engine, we had to drop the starter motor to get to that one...
when i got my 32 it was running stock boost, seemed fairly quick for the first few weeks as its my first turbo and wasnt used to the power change when it hit into boost. Got bored of it so had it dyno'd at hyperdrive to check a few things out and the guy asked me if i wanted to turn it up a bit, i said yes of course :P it is now running 13psi on the high boost setting and has been fine, mind you i only turn it up when i want to give it a bit of a boot. I also only have cat back exhaust and he said it should be fine as long as you dont boot it every day to work on the highway.
got a question of my own, im getting the dump pipe fitted soon and going for a bigger turbo, ive heard the rb25 runs well but want a bit more of an upgrade, any ideas of whats a good turbo upgrade to get?
cheers
I hammered my RB20 turbo at 14psi everyday, and again with the 25 turbo at 12psi. No problems whatsoever ;)
Then I got sick of no bottom end and having to give it 3k and drop the clutch to take a gap in traffic.. RB30 FTW!
lol where'd you get that idea from?
The wastegates are physically the same size.
http://www.skylinesaustralia.com/forums/Sl...20&start=20
look at the pictures
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
