hey,
just a quicky :blink: just wondering how much boost an rb20 turbo can hold safely, im running 12psi through mine but dont want to go anymore cause i have heard lots of stories of ceramic turbos shattering and getting sucked back into the combustion chamber.
should i maybe turn it back down to 10psi till i buy an rb25 turbo or can i leave it at 12 for a while????
Cheers
Matt
https://www.sau.com.au/forums/topic/185039-rb20-turbo-question/
i have sitting next to me a peice of my friends r32 turbo compressor wheel which shot out through his exhaust.
He was running 15psi + flutter, did a couple of drag runs and bang pop.
I think safe boost level is 13-14psi although quite a few people run at 15psi.
Cheers
you can get away with running 14psi on the rb20's most of the time, but it's best to get it on the dyno if you do to see if it's running lean.
yeah i haven't put my dump pipe on yet so i might wait till i put it on before i turn it up anymore i also want to get a dyno test done but i think ill wait till the next dyno day
  • 2 months later...
I'm running 14-15psi but my engine and turbo are low km's. Does it fine, no probs at all. One of my mates has also run his for over a yr at 14-15psi no probs. Wow, even if a turbo lets go after 2 years thats a huge total cost of like $80 a year for a lot more fun. 11-12 is safe as (If it lets go ure turbo is average anyhow) but i'd run 14psi and no be a b!tch.
Cheers
i'm running 12.5 and havn't had any problems. i hear 12 is safe and 14 is pushing the limit but this is just heresay. i guess it also depends on your driving style, how you maintain your car, and how many km the turbo has done. just make sure you give it enough time to cool down after a hard run and keep it out of high boost in the heat.
I'm just going to add my bit to the above - which are all good opinions. However, I can see you really want a definitive answer. So:
It actually comes down to each car. Now you ask what part? Well, its the whole thing, including the driver!!!!!!! I've developed a simplified formula for you:
The second page got beer spilt on it so I decided just to skip to the last equation:
RB20DET ~ 10-15psi.
Hope it helped :laughing-smiley-014:
dude if your gonna upgrade then I would go a 2530 or 2510...maybe something from trust. The R33 turbo is an improvement over the RB20 as it has a larger wastegate..but its still ceramic...I had a 2510 on my RB20 and it ran beautiful at 16 pounds..If you are gonna go to all the trouble of changing dump pipes then while you are there change all the water and oil lines with brand new ones.They are a nasty thing to change at the best of times, specially that water hose around the back of the engine, we had to drop the starter motor to get to that one...
when i got my 32 it was running stock boost, seemed fairly quick for the first few weeks as its my first turbo and wasnt used to the power change when it hit into boost. Got bored of it so had it dyno'd at hyperdrive to check a few things out and the guy asked me if i wanted to turn it up a bit, i said yes of course :P it is now running 13psi on the high boost setting and has been fine, mind you i only turn it up when i want to give it a bit of a boot. I also only have cat back exhaust and he said it should be fine as long as you dont boot it every day to work on the highway.
got a question of my own, im getting the dump pipe fitted soon and going for a bigger turbo, ive heard the rb25 runs well but want a bit more of an upgrade, any ideas of whats a good turbo upgrade to get?
cheers
I hammered my RB20 turbo at 14psi everyday, and again with the 25 turbo at 12psi. No problems whatsoever ;)
Then I got sick of no bottom end and having to give it 3k and drop the clutch to take a gap in traffic.. RB30 FTW!
lol where'd you get that idea from?
The wastegates are physically the same size.
http://www.skylinesaustralia.com/forums/Sl...20&start=20
look at the pictures
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
