  • Replies 92
Hi guys,
Well it's time to get new tyres again (for the rear only thank god).
Currently running Kumho KU31 - 275/30/R19
The tyre place has given me the option of a few (all 275/30/R19):
- Toyo T1R: $500 per tyre, fitted & balanced
- B/Stone RE001 - waiting on quote
- Kumho KU19 - $370 per tyre, fitted & balanced
- Kumho KU31 - $345 per tyre, fitted & balanced
These prices seemed to be better than what I was getting through a wholesaler.
I've been told the RE001s and the T1Rs won't last me long but just grip like all hell and I'd probably never exploit the true potential of those tyres by driving on normal roads. (running -2 rear camber)
I'm leaning towards the KU19's. Any thoughts?
cheers
Hi guys,
cheers
I blew a tyre on Saturday... same size as yours but I got my Kuhmos for $270 @ Tempe Tyres.
For KU19s? If so that is an excellent price. The KU19's are 2 weeks out of Melbourne (i.e. none in WA) so he's put in a back-order - should be in Perth by around mid-Oct.
Are Tyres generally cheaper for you lot on the East Coast? A lot of stuff seems to be a bit pricier in WA :mad: . But not by the margin between what you paid and what I got quoted
  • 6 months later...
Dunno if I should be bringing up this old thread again or not - wondering if anyone can tell me the wear rating for the Kumho KU31?
Also, has anyone ever tried Continental ContiPremiumContact or ContiSportContact tyres?
bought "Rotalla" chinese tyres from fleabay.... $90 each plus 15 delivery.... 19's for less than $500 a set and worth every cent. quiet too.
have had experience with simex in the past (on road and wet race) and can recommend those aswell...
I have the ContiSportContact 2 on the front and they're pretty grippy. Much less understeer compared to previous jap spec Bridgestone Regno tyres and noise is minimal.
Anyone out there have the Potenza RE050A and how long they typically last?
I'm currently running the RE050A - I think they were brand new when I got the car but can't be 100% on that. Anyhow, done a tad over 30k km on them, maybe 34k max, and they're worn out.
Have ordered the Continental PremiumContact 2 which are going on tonight. Will let you know how they go.
  • 8 months later...
I have Bridgestone Potenza RE50A on all four wheels.
They came with the car when I imported it.
The car had 14xxxkm on it and now 57000km (almost), so 43000kms I've driven. The rear's have about 10% left, and the front tyres have about 50-60% left,
I didn't like the wet grip on the bridgestone RE50A, the rear loses slight traction if I hit a lane marker (or a similar small bump) above 80km/h, and slightly scary at acceleration going up hill, if pushed above 4800rpm in 2nd gear the rear loses traction in the wet but I guess that is natural... This happened before I installed plenum spacer + z-tube
But dry traction is SUPERB ! Braking in the wet is also very good :)
I think I will try Kumho KU31 for my rears. I want to sell my car so I don't want to spend too much, but I still want decent tyres for safety reasons.
My car comes with i think the stock Bridgestone Potenza. Anyone know how good they are compared to those tyres mentioned here? Thanks!
Have my new RE002 for 2weeks now, good grip and less noise than my ex-Korean tyre-KUMHO, $$ of mine is not bad! $250 each for a set inc alignment and balance...
Wow that is very cheap!! Where did u get that price and what size?
^ +1
I have a set of Invo's on the way. I'm looking forward to seeing if they live up to most of the reviews. Got mine for ~$200e delivered.
It's a great bargain from the Bridgestone shop in Brisbane! I choose most common size for 4 wheels, 235/45/17 to fit my Nissan OEM wheels.
The package is also included puncture free warranty and rotation after sales service.
Nice price. What size Leon?
245/45/18 - same size as most M35 guys are running. To be exact, they were $189 + $15 delivery, which I thought was good enough for me to give them a try. If they don't wear as good as I hope, then it's not like a paid $300 each. Other choices from local suppliers were either rubbish lesser quality than I like or too expensive - often both, lol.
Edited by Commsman
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
