I'm new to the Skyline world and theirs only 3 in my city so this Canadian needs some questions answered.
I was wondering if the GTR speedo and tachometer will fit into a r32 GTS-T because i want to put in a Mines 0-320 speedo and a 10K tachometer from a r32 GTR. Right now my cars sitting in my garage with a blown clutch i cant fix right now so i'd like to put in a new speedo, tachometer, and Greddy Emanage Ultimate with profec controller allong with my clutch and related modes so i can see if the technical stuff works well before the winter mod season starts.
Much appreciated. From the great white north.
Edited by LedZepLen
https://www.sau.com.au/forums/topic/185069-gtr-speedo-in-gts-t/
That took a suprisingly long time for an answer. This forum must be smaller then i expected because lots of the time if a thread isn't replied more then once a day they get lost in the site.
THANK YOU Australia!!!
Now, why are their BNR and HCR body kits for Skylines; i know what each is but do the holes all match up the same??Do the manufactures just make it so they fit the intercooler layout of the GTR or the GTS-T. I see allot of kits for BNR 32 and not much for the HCR 32. I dont see would take care of. If this answers "YES" then i've got my 2 possibly dumb questions taken care of and if it's "NO" then i guess it wouldn't seem as dumb. Keep in mind this year is the only time in my entire life i've seen a skyline, second skyline i've ever seen i bought because i could have sat their the entire day on a lawn chair stairing at how good they look, plus it's in the best condition i've seen r32's in to this date.
The difference between BNR and HCR is becasue the front and rear guards are wider on a BNR making the front and rear bars wider.
As for the intercooler fitting behid the bar, that is something you do when you fit the bar. A grinder does the job it you need more room
however aftermaket kits seem seem to fit with the intercooler without and cutting.
You can make a BNR kit fit but it will need modify.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
