Yeh the damage wasn't that bad on mine, they got in and only opened the ashie and centre console! Nothing taken!
Yeh i had some issues with my alarm a year or so ago, and had put the siren off! The alarm was still on and the immobiliser worked, BUT in saying that there is NO damage to the interior to show that they tried to start the car!!
ALARM IS NOW TURNED BACK ON!!!
We were HEAPS lucky, some of you guys havent been so, and some have yet to be targeted, SO just alarm them and keep em safe, them coming to our house in broard daylight and down our driveway means NOWHERE is safe!!
Sorry to hear about the breakins to your pride and joy('s)
On another note, the knife look's like a hack knife . It is sold in hardware stores and used for cutting metal by taping the top of the blade with a mallet .
Hope the damage wasn't to bad.
Interesting savage, it was puzzling my because it looked quite crude, and was very heavy, but looked too good to be a DIY.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
