Hi guys
Just a quick post to introduce me and my ride.
Been a long member of nissansilvia.com and secretdrift and an even longer owner of a couple s13s but have just bought a new daily. A 32 GTS-4 90 model that is immaculate with 80 000 on the clock. Seems to be a very nice car but very standard atm. will be putting on a set of dishies and some coilovers but apart from that not much at this stage as it will be a daily.
See you soon.
John
https://www.sau.com.au/forums/topic/185084-introducing-me-and-my-32-4-door/
  • 1 year later...
Has been a long while now but here are some new photos..Car now sports Greddy intake kit, R34 turbo and ARC sidemount, 3in turbo back kakimoto exhaust and high flow cat and KTS coilovers to bring it down to earth...Also painted the center of the work wheels black to be "dish decieving" :D
What do you guys think?
  • 1 month later...
  • 3 months later...
  • 4 weeks later...
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
