  • Replies 58
cool, I'll add you tonight mate. I did add the other guys too but they haven't accepted yet? quandons etc. just check your clans area and there should be an invite there. :thumbsup:
god it will be nice to actually play a team game and work as a team. getting sick of being killed by knuckle heads on my own team and basically just having people off doing their own random thing. espcially in the TDM you really need to team up with at least 2 guys (but 3 or 4 is better) then go pick off the enemy as you usually can get them alone or 2 together. same goes for CTF and ZNS too I guess.
https://www.sau.com.au/forums/topic/185133-warhawk/page/3/#findComment-3459779
  • 2 months later...
Hey Bear Baron I just got this game and would also like to join your clan my PSN is Smurf80 let me know when you have added me and ill jump on. Ive played it twice now and are starting to get the hang of it. Talk about a steep learning curve!!!
https://www.sau.com.au/forums/topic/185133-warhawk/page/3/#findComment-3605262
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
    • Throws on the FS5R30A in most Nissans of this era are actually quite short and direct compared to any remotely modern BMW with the S6-53 transmission. Those things have throws a mile long with rubbery vague everything. Synchro issues combined with a short shifter is just going to break everything even faster.
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
