R33 Gtst Hit And Run
Quick update, finally got an hour or two on a weekend where there wasn't shit weather, no sick kids, people visiting our house or had to work. Visited me old folks and the skyline...dropped $10 of 98 in the tank and a brand new SCA shitter battery in. Cranked over a bunch of times but didn't fire up....pretty sure it's not getting any fuel. Gonna try some of the stuff suggested above, next time I make it over there.
@GTSBoyas luck would have it and it's legit the only part of this story that goes my way, I already had the liner out to retrim! So much lucky!
Drill out the subframe bushes, replace them, same with the diff bushes. -
Sane enough. Remove the roof liner, because the acid will go everywhere.
Thanks guys, I really appreciate the help and experienced opinions. I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here; I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes. Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner. Does that sound sane? Is one type of filler better than others for this?
