Hks Rb28 Build Update
SLY33
 Share
be interesting to see your results, a mate fitted the 650 to his 1j and the claims of 30% better spool than an equivalent garrett didnt pan out, she is extremely laggy (5000rpm?) but that being said the car makes alot more power than it did with a .63 reared gt35 on the same boost (440 to 480rwhp)
whatever you do dont damage it, waiting time on replacement parts for the turbo is in the 2-3month range
Edited by DCIEVE
  • Replies 66
Nice engine SLY33, ex maniforl is a work of art!
Just a quick question though (provided its not top secret info):
What cams are you running in that purple beast?
Good luck on the engine dyno! Im sure she'll pull out some serious numbers once run in!
cheers guys.
the engine dyno im using is currently apart for some maintenance. im hoping to get it run in/tuned as soon as its back together.
Cams are Jun 272's. It will be interesting to see how this thing drives, everything about it has become more focussed on top end flow, rather than response. The only drivability/response component in its favour is the 2.8litre stroker crank! There was going to be a 6 throttle nismo plenum to help with the response, but that got put aside for the all-out hypertune manifold.
All i want of this build is to have a bit of a scare when i find enough road to put the foot down. If i want a good responsive package and some tail out fun, well thats what the GTS-t is for :miner:
(for those that were interested in the extrude honed stock manifold results on my GTS-t, it should hopefully be on and tuned in a couple of weeks, will post the results)
Edited by SLY33
All i want of this build is to have a bit of a scare when i find enough road to put the foot down. If i want a good responsive package and some tail out fun, well thats what the GTS-t is for :stupid:
Very nice - look forward to seeing how this comes out. Are 272s big enough for an 850hp odd turbo?
A friend of mine is putting one of those G-TK 1000s on his 25/30. His engine is currently being built, im sure he will post his results when its all finished.
  • 6 months later...
  • 3 months later...
So far it made 760HP @flywheel at 24psi. Would have liked an even 800 but i guess its more than enough as it is.
its going back in the car now, will try get some pics up. Will be interesting to see how the rwkw reading will translate back to the flywheel reading once its done.
is there gonna be a significant difference at the end of the day with a x-force vs another?
I just used what the engine builder rec'd, he reckons it will do the job..
btw fuel is 98 pump plus 10% methanol
But yeah she looks pretty laggy! Goes something like this, 4000rpm 200HP, 5000rpm 300HP then between 5000-6000 rpm the power doubles from 300-600HP. Peaks somewhere round 8200rpm.
Will get the dyno sheet up..
Looking at the power delivery, if i were to build again id definitly go a 3litre and perhaps a slightly smaller turbo. But no doubt this will still be fun :yes:
Edited by SLY33
Nawww no aircon :)
Dude! Tell me about it! I said to my engine builder i wanted to keep it, but no room for condenser and fan.. He said later on we could do something custom... Car will barely get driven anyway as i dont live in Australia anymore! Offers to buy this car may be considered!
 Share
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
    • I installed it all myself,  It was really easy to install.  I got a professional to do the degas/gas.
