they'll both hold up fine. as long as it can keep the pressure up, which either a walbro or a gtr pump will be able to do, in the case of N/A.
So get whatever is cheaper for you.
GTR comes with 300hp factory. and can pump for about 400 or more. so you'll be fine with either.
No.. Not unless the old pump was on its last legs and leaning out.
Thats right, there is no point.
If anything it will just run slightly more rich, which is pointless..
Edited by abu
why will it run more rich?
fuel pressure is controlled by the FPR so at the end of the day you can stick a bigger fuel pump and the extra flow provided if its not needed with just be sent back to the tank.
As mentioned, the pump will only make a difference if the old one isnt up to the task, if the old one is capable to send the amount of fuel needed to hold the correct pressure to the fuel rail right through the rev range the wont be a difference.
if the new pump is capible of flowing more fuel at the same pressure yes you will run rich, you would need an adjustable fuel press reg to tune it to optimum presure then you might be able to squese a little bit out of the upgrade but its really not worth it at all untill you neer to or over the flow rate of the current fuel pump, if youve upgraded a lots of things already, ie exhause intake cams, ecu, or turbo conersion ect then yes you will need one but on a stock car its pointlesss
the r33 that we installed a 023 into didnt change in the slightest with the new pump, and thats a pump that is rated to 700hp. Didnt run more rich, and nothing else was changed ie it still had the stock fpr.
i know what your saying but in stockish appilications i dont see how it would make a noticeable difference to the afr
i push a bosch 023 on my car, pushed the fuel pressure from 32psi to 40psi, but thats probably just because of the higher pressure from the pump on the adjustable fpr.
i noticed more response, also - when you revved the car with the old pump the fuel pressure dropped right back and slowly build up (leaning the car obviously when you first stomp it) now it never dips, so its better in that respect.
but then my car needed it, as it now makes over 150kw, and it had a stock r31 pump made to feed about 80...
the only time a new pump will make any difference is if the old one isn't doing the job. i installed a 040 into a mates 33 and it dropped about 15hp cause the old pump was dying and causing it to lean out a bit. the new pump dropped the AFRs to where they should be, and stopped it pinging its arse off.
exactly, there wont be a gain in having a bigger pump, but makes things a bit more reliable if your starting to ask for a fair bit more power than stock
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
