Blowing White/grey Smoke -> 1 Plug Tip Is White?
Mr_GaZZa
 Share
Hey every1,
omg i cant believe it, i am blowing smoke... smells oilly!!!
more on tick over or crawling... and on standstill when u give it a REV...
its never done it b4
got my car boosted 'with manual controller' and dyno'd @ streetforce... i said i only wanted 10PSI
but the bugger tired for more when i got cash out!!! n said that didnt make much more power @ 14psi
i mean then he turned it down to 10ish!!
DAM!! what is gone? how can i look for wat it is? would i be valves guides? turbo? piston rings? :)
i am so angry now at him for that!!
HELP ME PLZ
GARY
Edited by Mr_GaZZa
undo some of your cooler pipework and look for oil in the pipes
if you see a bit, wipe it away then run the car again
if it comes back quickly then youve probably shagged the turbo oil seal
or it could be leaking on the exhaust side, which is whats making it smoke, as you have raw oil leaking into the exhaust housing
:unsure: yeah i took one pipe of b4 it goes into the intercooler... looked coated in oilly stuff :P so gave it a clean.. going to install n start up again!
if its the rear , just remove the frontpipe n look?
if your referring to the exhaust side youll need to drop the exhaust off at the dump pipe / front pipe area and look from there
its natural for some trace amounts of oil to be there (visual) but it shouldnt be dripping / fresh
:P
okay working on that bit now!!
um... what / where can i find my PCV ... heard other ppl mention that with this issue... maybe mine needed a replacement.. awhile bk i had idle problems n kinda fixed it self
with lil adjustments to the idle screw!!!
also only other problem i had was WRX sound randomly... but only in winter /dampness ... once a week at most... maybe they where signs =(
hasnt done that for 2months but
omg :unsure:
sounds like broken pistons.
NO NO!!! aint lost no performance, no heat gains, no real oil usage or any WIERD noises
i thinks its the rear turbo seals
any1 else got any ideas??
BTW cars nearrly done 160 ### km
GaZ
hey all :laugh:
been working / finding out stuff all day about my car!!
only smokes when hot, and only after its sitting ther n u give it a rev u get a lil puff...
it doesnt smoke when or acceleration or de/ acceleration and doesnt smoke when cold!
performance is same, oil pressure remains to its normal pressures i see and engines temps are well under half way !!!
me thinks it REAR turbine oil seal =(
LF new turbo / or place in Perth to rebuild it....
Gaz
P.S thanks every1 for ur input
Edited by Mr_GaZZa
sounds like pistons to me, i had this problem too, same colour smoke ect. still had good performance, but blowing heaps of smoke and using up my oil. took it to my tuner he tells me its pistons.. pulled the engine to bits and all 6 ringlands were f**ked :laugh:
sorry, probably not what u want to hear, but before you get the turbo rebuilt get a leak down/compression test done
Yeah, there is a way too find out which one it is
while doing a compression test.
I'm not too sure how to do it!
But i think it's were you put oil on top of the cylinder
and then when you do the compression test,
if it goes higher its your stem seals or if it stays the same
it's your rings.
Not too sure though so if someone could correct that will be good.
noooooooooooooooooooooooooo!!!!!!!!
:laugh: RAWR
i hope its just something cheap/ easy to fix
omg BS >< if it was pistons wuldnt u be burning oil.. n wuldnt it be worse @ cold start :S
and i dont get no smoke while cruising... n stuff all or if any when pulling away **looks in mirrors**
also took off oil cap, no signs of back pressuse or spitting, just a slit change in idle...
thanks guys.... i'll keep my options open, until i go to a few yards n mates @ tuning shops / nissan n see wat they
say 2
thanks ;)
BTW compression test will be done this w/e coming
Edited by Mr_GaZZa
thats right.. if u put in oil and do the compression test it should help verify wether its valve guides, stem seals etc
just becareful wat shops u go man same thing used to happen in my other car, not a nissan but under load/boost it used to puff a blue smoke.. and sometimes on vaccum once cruising car slowing itself down from 80,60 it used to blow alot of blue
went to tonnes of workshops they said needs a rebuild, some said rings r going, some said valve stem seals or valve guides..compression tests came up fine. opened it up myself it was only a manifold gasket cracked,
even when i used to rev it at neutral up to 3 grand for 10 seconds then backoff it started to blow the blue.
sometimes its not as bad as it sounds.. get compression test first, start ur way from the bottom and go up
 Share
